FDX mode on 6500 issue when using digital modes
Wim
I was trying out the FDX mode on my 6500, while transmitting JT65 on 40m
I was trying to receive on 20m at the same time.
The FDX works when I key the transmitter on 40m using the foot switch, I can continue
to receive on 20m during the transmission. However when WSJT-X keys the transmitter
via the CAT command, the receive on 20m is muted.
The WSJT-X is using the CAT method for PTT I am not using a separate COM port just for PTT.
Using latest smart SDR software here, anyone else seeing this or do I have something misconfigured.
I do not believe the radio is misconfigured. I have entered this problem report into our bug tracker as defect #3153 for additional investigation. Thank you for the defect report.0
What are your transmit and receive antennas set to?0
My transmit antenna is ANT 1 and the receive antenna is RXA.
This morning trying this again, I didn't see the failure initially but then playing with it some more
I saw the issue again, this time when pressing the foot switch on 20m slice (bottom one) the audio
would get muted but not when tuning from the WSJT-X on 40m slice ...
See screen shot of my slice setup where I see it now:
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
