DDutil macro help
G8ZPX
Hi,
I am looking for anyone who is familiar with DDUTIL macros. I am not sure if this is possible, but what I am looking for is to create a single macro and button in DDutil that does all of the following functions in rapid order. Assuming slice A is already tuned to Fq :-
Enable Slice B
Tune slice B to Fq+5kHz
Switch TX to slice B
Move audio of B slice fully to right speaker/earphone
Zoom panadator/waterfall to show +/- 50 kHz either side of Fq
Anybody able to help with this please?
73 de Steve G1XOW
Enable Slice B
73 de Steve G1XOW
DD6SPL05;DD6PBW0:.1;DD6PCF0;DD6AUP1:100;
If slice A is open in a panadapter, 1 click on the macro button will open the second slice B, set TX to slice B, set the pan bandwidth to 100khz, center the slices in the panadapter and set the stereo field to 100% right. A second click on the macro button will separate slices by 5khz. If slice B is already open one click will set focus to slice B, set B to TX, set pan to 100khz, center slices and set the stereo to 100% right. A second click will separate slices by 5 khz.
DD6AUP1:050; will set stereo back to 50%
The syntax is critical so cut and paste
73 W9OY1 -
I'm totally inexperienced with the macros. Where do you put them and how do you invoke them? I've seen a list of macros in DDUtil Wiki ... is there a How To on using them somewhere?0
The macro buttons are turned on in the setup>features tab Macros are stored in a database under the Macros tab. Macros are powerful commands that control the radio
73 W9OY0 -
Yes, I've seen that but how do you invoke a macro? I see no way to add "buttons" to the SmartSDR User Interface. It appears that perhaps macros can be assigned to existing SmartSDR UI elements - true? Can you create a new UI element (e.g., a button, a drop-down list of options, etc.) and assign a macro to it?
It works the way it works, which is what I told you. Now you're going to have to spend an hour figuring it out. My impression is you actually have not spent any time on this. One suggestion is you "save as" the database under a different name . If you make changes to the default database and you need to reinstall your changes will be overwritten0
I'd love to try DDUtil but I can't even find a link to download it from!
If I go to the DDUtil v3 Wiki page I either see just loads of blank pages (http://k5fr.com/ddutilwiki/index.php?title=Main_Page) or I get into a loop - this page: http://k5fr.com/DDUtilV3wiki/index.php?title=Download sends me to this page: http://k5fr.com/binary/Release32200.pdf which sends me back to this page: http://k5fr.com/DDUtilV3wiki/index.php?title=Download
Whatever I do I can never seem to find a downloadable file that I can install from.
Could someone post a working link for me?
David G4NRT
David....go to this page http://k5fr.com/DDUtilV3wiki/index.php?title=Download#Download_V3
on this page click on DOWNLOAD V3 (blue letters) the download will start automatically...
Have fun...
Steve1 -
Doh! I must have clicked everything else but didn't see that this was a link!
Thanks!
David G4NRT
When you make a DDUTIL macro make sure to copy the command exactly and always end a command with a semicolon ; You can string commands together but each command in a string must end in a semi colon. DDUTIL will work across a home network so you can have custom databases for example if you use the radio remotely but have slightly different needs. For example if I was using a laptop at the base of the tower I would have a bunch of macros to tune the radio to specific parameters for specific antenna tests I wanted to perform. This way I would get consistent test results across testing sessions
73 W9OY0
- 636 The Flea Market
- 143 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
