FLDIGI, DXCluster with Azimuth and Country Listings?
KY6LA_Howard
Member ✭✭✭
My friend Janny ON5PO asked it anyone had any idea how to use FLDIGI with a DXCluster
AND
have the DXCluster report both the Azimuth and Country listing of the DX Station?
Yes we know about
I suppose Janny could run HRD Logbook with Spots which gives both Azimuth and Country but the preference is to have it integrated with FLDIGI
AND
Yes we know about
http://www.n2amg.com/software/fldigi-dx-cluster/
But it does not display Azimuth and Name of CountryI suppose Janny could run HRD Logbook with Spots which gives both Azimuth and Country but the preference is to have it integrated with FLDIGI
DXLabs SpotCollector shows the information Janny wants and Rick N2AMG has written a SpotCollector-FLDIGI bridge. I've used it and it works as advertised:
http://www.n2amg.com/software/fldigi-dxlabs-gateway/
Rick monitors the DXLabs and the FLDIGI reflectors, and will can help Janny if he runs into any issues.
Mike - N8MSA
Hi Howard, looks like ok :
Hello Sergey, the value azimuth (bearing, is not good, I placed my grid jo20sn in map setup well
he/it gives me for 4w/pe7t 324°/144°, I should have + / - 40°
or I must correct
it is the bearing of the spoter, not, in relation to mine
thank you
on5po, Janny0 -
Hi Janny, i am sorry, you are right , good service to control online here:
http://ns6t.net/azimuth/azimuth.html
with my grid KO85TO bearing on DU3JH should be ~85°
i think need mail to Rick
BTW this is OFF TOP here, i am sorry !0 -
Sergey ,
again a window in more, it is possible to add "Country and azimuth in the fentre cluster as in HRD
Janny0 -
i have mailed already to Rick let's see for answer0
Hi Sergey..
I just checked and the bearing is indicating correctly. The calculation for setting the bearing to the station is the exact calculation that is used in Logger32. Are you sure you are setting your latitude and Longitude correctly. South and East numbers need to be entered as negative numbers. I also just switched the map in Logger32 to show the compass heading on the map and it is correctly pointing to the correct bearing on the compass head. If you have any other questions please write away..
73 Rick N2AMG
Hello Mike, we don't find DXLabs SpotCollector
if you had more information
thank you
Janny0 -
Actually after looking at this I do see an issue. I put in your Grid and it gives me your location. But the numbers in the bearing become backwards. Where the short path is on the right and the long path is on the left. I will correct this but its going to be a little bit. Busy at work and I need to familiarize myself with my code again. I have not worked on this code in 2 years..1
Janny.
It is located on the DXLabs website. Its a major part of the suite.
I think the address is www.dxlabsuite.com
73 Rick N2AMG0 -
I have just posted an update on my website for the FldigiDXCluster Software application. This update fixes:
1. The calculation for calculating the Short path and Long path bearing has been corrected.
2. When you changed your latitude and longitude the change was not reflected in the calculation. You not need to restart the program after changing these settings.
3. The country Name is not displayed in the mouseover information for spots on the map and is also added to a new column in the Spots Grid.
To install the update download the update file and unzip the file over your currently installed FldigiDXCluster files.
www.n2amg.com
73 Rick N2AMG0 -
The country Name is now displayed
I can't download the update for FldigiDXcluster . Not possible to display the page (Error)
How can I download that update ??
730 -
Here is the direct link to the file:
http://www.n2amg.com/files/FldigiDxClusterUpdate.zip
Can you send me a screenshot of the page error you are seeing?? I do not see any page error on my browsers..
Thanks and 73
Rick N2AMG0 -
Here is the display attached. The page can not be displayed on my screen
OK it should work now. didn't realize I was looking at a cached page. it now downloads correctly ..0
Try Commcat (commcat.com).
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
