Which Heil Proset adapter cord will I need to connect to the Maestro?
Robert Scott Ireland
- Microphone 1: Pseudo-balanced 8-pin RJ-45, dynamic or electret compatible (Same “Yaesu type” pinout as FLEX-1500 and FLEX-3000)
- Microphone 2: Pseudo-balanced ⅛” (3.5mm) TRS, dynamic or electret compatible
- Microphone Impedance: 600 Ohms Nominal (200-10kΩ)
- Headphone: Stereo headphone jack, 1/8″ (3.5mm) TRS
- Headphone Impedance: 16 Ohm at 25 mW, 32 Ohms at 13 mW with THD+N: 0.02%
This one for the RJ-45 connector
http://cart.flexradio.com/ProSet-Headset-Cable-for-8-pin-RJ-45-connector_p_28.html0 -
Thanks.
So, for the Proset 6 and Proset Elite is seems that the correct adapter is the AD-1-YM.0 -
Thanks Tim, I had just come to the same answer using the Heil website.
Tim, to answer your emailed question (although I don't see it here, wierd) - I am using the Heil Proset 6 with my Flex 6300 (purchased from FlexRadio when I bought my 6300).0
Yes, that is correct.0
I removed it once I saw the headset reference.0
Why can't you just plug the pro set 6 into the 1/8" Jacks?0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
