Which Heil Proset adapter cord will I need to connect to the Maestro?
Robert Scott Ireland
edited May 2019 in Maestro
  • dlwarnberg
    dlwarnberg Member ✭✭
    edited May 2019
    • Microphone 1: Pseudo-balanced 8-pin RJ-45, dynamic or electret compatible (Same “Yaesu type” pinout as FLEX-1500 and FLEX-3000)
    • Microphone 2: Pseudo-balanced ⅛” (3.5mm) TRS, dynamic or electret compatible
    • Microphone Impedance: 600 Ohms Nominal (200-10kΩ)
    • Headphone: Stereo headphone jack, 1/8″ (3.5mm) TRS
    • Headphone Impedance: 16 Ohm at 25 mW, 32 Ohms at 13 mW with THD+N: 0.02%
    Can't find any additional information on it
    edited March 2017
  • Robert Scott Ireland
    edited April 2019
    Thanks.
    So, for the Proset 6 and Proset Elite is seems that the correct adapter is the AD-1-YM.
    edited October 2015
    Thanks Tim, I had just come to the same answer using the Heil website.
    edited March 2017
    Tim, to answer your emailed question (although I don't see it here, wierd) - I am using the Heil Proset 6 with my Flex 6300 (purchased from FlexRadio when I bought my 6300).
    edited December 2016
    Yes, that is correct.
    I removed it once I saw the headset reference.
  • Mal
    Mal Member
    Why can't you just plug the pro set 6 into the 1/8" Jacks?
