DAX TX with hardware PTT
K1DBO
Member ✭✭✭
I'm having trouble sending voice to my 6500 via the DAX TX channel while using a hardware PTT switch. VOX and MOX work fine But, the hardware PTT switch seem to only key the physically connected mics. I can see that making sense in many cases, but it's not what I'm looking to do. Am I missing something? The interface to SDRCat has me thinking that I can map a hardware serial port to an SDRCat PTT port but I'm not at all sure it means what I think it means.
I had a similar question asking if the PC input could be keyed with a footswitch. It is actually disabled and I think DAX would be too for some reason. Tim explained it but I think it needs to be reconsidered.1
The only thing you're missing is a previous recent thread that discovered the same thing.
Barry N1EU0 -
As it turns out... you can use a hardware PTT to key the DAX TX channel. It might even work to key the PC remote input as well but I didnt test that. I just used SDRCat to map a hardware (existing) serial port on the computer as a PTT port. Then, I put a cable together to short a couple of pins with a footswitch, yada yada, footswitch now keys DAX TX.
I was expecting to short pins 5 and 7 to make this happen. Maybe I did. But my meter seems to be telling me I'm shorting pins 7 and 8. I'll take a closer look for crossed wires later. But for now, everyone can rest easy knowing they can use a footswitch.
While it would be nice to use the hardware PTT inputs on the radio itself, this solution only requires a simple cable and even allows taking the footswitch to a remote computer.
Now if I could just get the footswitch to enable/disable VOX instead... but that might take external software.
...of course this was probably already mentioned in a previous post too.
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
