SDR-BRIDGE 1.5.0 mutes audio
W5UN_Dave
W5UN_Dave Member ✭✭
edited February 2019 in FLEX-6000 Signature Series
The new v1.5.0 SDR-Bridge no longer lets me disable the mute when I add a slice. How do I now disable the mute feature?
  • Ed - W2RF
    Ed - W2RF Member ✭✭
    On the Radio tab make sure "Mute all but active" is not checked. This is the only option that affects audio muting. If you still have a problem, please post more details or open a support ticket on http://www/qrv.com
    73 Ed W2RF
  • W5UN_Dave
    W5UN_Dave Member ✭✭
    edited November 2016
    Ed, I find no "Mute all but active" option on the radio tab of 1.5.0.123. It was there on the earlier version, but now I only see the window showing frequencies. Am I missing something? The link you show does not work, so I posted here instead.
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited December 2016
    Hi Dave,
    The Link should probably be:
    http://www.qrv.com/
    Here is a snap of what the radio tab should look like...
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
    6700 - HW.................... V 1.6.21.77
    SSDR / DAX / CAT...... V 1.6.21.159
    Win10
  • Ed - W2RF
    Ed - W2RF Member ✭✭
    Dave,
    Al's snip is what the Radio tab is supposed to look like. Please post a snip of yours so I can try to figure out what's going on. But first I recommend uninstalling and reinstalling SDR-Bridge.
  • W5UN_Dave
    W5UN_Dave Member ✭✭
    Ed here is what mine looks like
  • Ed - W2RF
    Ed - W2RF Member ✭✭
    It  looks like you have a legacy theme selected. What version of Windows are you running?
  • W5UN_Dave
    W5UN_Dave Member ✭✭
    running Windows 7 Ultimate 64 bit (legal)
    I've totally deleted, rebooted, and reinstalled. Still no joy. The previous version showed as NN4ZZ's snip.
  • Ed - W2RF
    Ed - W2RF Member ✭✭
    Do the other tabs display properly? Except for adding the Knobs tab, there were no other changes in the UI. So I believe there is a problem with theme selection on your machine. Go to Theme Settings and check. I suggest trying the default Window 7 theme. If that doesn't work, try reinstalling v1.1.3 and see if it displays properly.
  • W5UN_Dave
    W5UN_Dave Member ✭✭
    Ed, themes has everything to do with it. I had to switch to the basic theme (showing the awful windows logo) and there it was. That is the only theme that will show the three check windows. I unchecked the MUTE, and switched back to my usual theme. Thanks for the tip.
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    Dave, If it's okay i'll add your snapshot and solution to the next version of my quickstart guide. Regards, Al / NN4ZZ
  • Ed - W2RF
    Ed - W2RF Member ✭✭
    I'm booting to Win7 now for further tests....
  • Ed - W2RF
    Ed - W2RF Member ✭✭
    In Win7 x64 Ultimate I did not experience this problem. I suspect that something is corrupt in your themes, but don't know what. I would need to be able to reproduce the problem to get a better understanding. Perhaps other users will have a similar experience.
    73 Ed W2RF
  • W5UN_Dave
    W5UN_Dave Member ✭✭
    yes Al, all is OK.
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    Thanks Dave.....will wait to see what else Ed or others also find. Regards, Al / NN4ZZ
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    My short report with Win7 here:
    i guess make sence
  • Ed - W2RF
    Ed - W2RF Member ✭✭
    edited February 2017
    Sergey,
    Your display is similar to Dave's. Did you try changing the theme to Windows 7 default? What theme are you using?
    73 Ed W2RF
  • Sergey R5AU
    edited April 2017
    Hi Ed, no themes in use at all - Windows Classic with switched off all effects. All settings for maximum performance .
    however........strange behavior, have tested with Win10 an Win10Pro Preview  - everything fine:
    hmmmmm ?
