Flex 6500 MRP40
Trevor-EI2GLB
HI All
I have just got a Flex 6500 and I am trying to get to grips with it, How can I key CW using MRP40 and the Flex,
failing that is there a CW macro option that I can program in some CW text to send ??
Trevor
EI2GLB
Trevor
EI2GLB
Have you looked at the CWX feature in SmartSDR?1
Or, better yet, read the entire manual.0
The rig didn't come with a manual, only a quick set up guide,0
Just seen cwx, is there any option to add macros and not have to type all the time,0
Download the SmartSDR manual from http://www.flexradio.com/downloads/smartsdr-software-users-guide-pdf/ and read pp126-128. There are 12 function key macro messages.1
CWX is great. You can interlace the macros (F1-F12) with regular typing. So in live mode you can do something like:
tnx for qso k6abc
(the above typed manually in live sends as typed) Then hit say F12 which you have your call programmed:
de ws7m k
So your type sequence would be: tnx for qso k6abc <f12>
Macros in the function keys can be longer. I have the following programmed:
F1: ws7m (just my call for pouncing on a dx)
F2: tu 5nn bk (answer to a dx reply)
F6: cq cq cq de ws7m ws7m (I can hit f6 twice to repeat then type a k)
F7: name mark mark
F8: qth fort collins, co co
This post shows how to use some prosigns:
https://community.flexradio.com/flexradio/topics/how_does_cwx_support_prosigns
CWX works great. I wish it supported the popular >>>5nn<<< to increase speed of 5nn and reduce speed. Maybe a future version.
If you want to use an external program then:
K9DUR morse keyer6K:
http://k9dur.rnaconsultingservices.com/smartsdr_utilities.html
MorseKeyer6K DOES support speed increase/decrease. It works very well.1
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 774 Maestro
- 42 FlexControl
- 728 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 374 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
