New Maestro data sheet
Chris DL5NAM
Member ✭✭✭
A new Maestro data sheet ready for download
http://www.flexradio.com/downloads/maestro-datasheet-pdf/
73 Chris
DL5NAM
73 Chris
DL5NAM
Changes i found:
Ethernet: 10/100/1000 Mbps
now
Ethernet: 10/100 Mbps
____________________________________________________________
8 Ohms with THD+N: 1%
now
• Powered Speaker Output: Stereo consumer line level
or powered speaker output, 1/8" (3.5mm) TRS
Electrical
• Power: 10-15 VDC
• Battery: Optional Lithium-ion battery
now
Electrical
• Power: 10-15 VDC
• Standard wall mount AC adapter
• Removable tilt hinge feet
• VESA to RAM® mount
• Li-ion battery pack with charger
• FlexRadio FHM-1 hand mic
• Wall mount AC adapter
now
• Tilt hinge feet (constant torque)
• Travel power pack (battery & wall wart). Each item also
available individually
• Carry case
Slower network speed? 10/100 down from 10/100/1000! Might or might not, be a problem for some. James WD5GWY0
Or a typo0
I don't think typo. 100 is more then max. needed
There are a lot of issues to manage with the very highest speed (1000 nominal) systems that FRS is wise to avoid.
Unless all parts of a home network are carefully done there is a reasonable likelihood the speed will fall back regardless, making the 1000 investment more risk than advantage.
Steve K9ZW0 -
Maestro consumes about 2.5 Mbps running full throttle.2
Steve, that and other connectivity issues, contention, slow or failing segment, etc is what the TCP/IP stack resolves.. What ever. Thanks Gerald, for clarifying the hwm.0
Bearing in mind that the Maestro is likely to cost around GBP1,000 (around USD1,500) here in the UK, it is quite disappointing that the feet and travel pack are optional extras. I have been pestering both the UK importers for prices for these - which I consider essential but they are not able to help.
Generally you just turn the dollar sign to a pound sign and you are there! Anyone know what the US prices for these options (and the carry case) are likely to be?
I am (like so many, I am sure) waiting for this darned device ...
David G4NRT0 -
The Maestro Includes free 30 degree angled feet Adjustable ftilt eet are extra Tilt Feet (ACC-MTF) Black anodized aluminum variable tilt feet with high quality constant torque hinges. Allows tilt from 0-90 degrees from vertical. Feet fold flat for easier transport of your Maestro. $99.95 Soft-side Travel Case (ACC-SC) Soft-side canvas bag with FlexRadio logo for on-the-go. Room for Maestro, headset and numerous accessory items. This case can alternately be configured to carry any FLEX-6000 series radio. $129.95 Personally the Maestro will go in my carry on bag on airplanes albeit with the new weight (10kg-13Kg) limits and number limits (1) on carry-on I might have to stick it in with luggage in both cases the extra bag is redundant. Extra weight0
Howard
We keep seeing videos of the flex. Are the feet on the flex in the videos the included feet or are they the optional extra tilt feet? Do you know?
Cheers
Wayne
Included; it's the standard base0
ok, thanks Chris
and flex in my post should have been maestro
Thank you for clarifying the feet and the carry-bag. What about the battery? What does it contain? If the Wifi in the battery enclosure or what? How about price? Finally, will there be a UK/EU charger?
David G4NRT0 -
Yes there will be a UK/EU charger $34.95. But likely they might ship a EU/UK charger with the unit to EU/UK. Albeit I need one for my travels The battery will be an off the shelf 12V Li Battery with auto start I expect Flex to publish a list of acceptable ones you could purchase locally to avoid the shipping of Li batteries issues.1
Thank you so much Howard. That is really useful information ...
73, David G4NRT0 -
Thanks Howard, I too was wondering about Li batteries, having read recently of airline restrictions with them.
The battery voltage requirement is actually 5V. While any battery technology is probably OK, the recommendation is for Lithium Polymer (abbreviated LiPo, LIP, etc) because of the compartment size and shape and the energy density of a LiPo battery. There are two ports required on the battery -- a female USB A port for discharge and a female USB Micro B for charge. There are other size, capacity, etc. requirements and recommendations and by Maestro launch we'll have posted these.
You should be able to buy batteries for about $25 that will last on the order of 5-6 hours each. While we have not tested this part of the design yet, Maestro should allow hot-swap of batteries meaning you will get a warning of discharge on the battery in the unit and you will be given some time (probably a couple of minutes) to put a new battery in without a restart of the Maestro occurring. This means you could pay on the order of $100 for 4-5 batteries and run Maestro off these for a 24-hour period with no external power and no restarts.
This is currently a "wireless only" feature -- if you are running wired Ethernet, the loss of internal power will disconnect the Ethernet and the radio will likely disconnect before you can juggle a new battery into place. We're thinking about whether this is a problem or not -- the general thinking is that you are most likely to run "shore power and wired Ethernet" or "battery power and wireless" making this a non-issue for the wired crowd.1 -
Steve what size (height, width and dept) of powerbank would fit the Maestro battery compartment? Any recommendation on capacity (10000+ mAh)? On youtube there is a video showing a Mogix powerbank, unclear what size or capacity that one is.0
This battery is not available in the UK. Will an alternative be suggested for buyers outside the US? I do not think that batteries of this type are allowed to be sent by air from the USA. David G4NRT0
http://www.amazon.co.uk/Foxnovo-10400mAh-Dual-Port-External-Smartphones/dp/B00NZOGDUY/ref=sr_1_1?ie=UTF8&qid=1455651163&sr=8-1-spons&keywords=10400mah+power+bank&psc=1 Check the dimensions but this looked about the same from Amazon UK0
This one
http://www.tenergy.com/51063
slightly longer (6" instead of 5.5"). Wonder if it would fit. I have aforementioned battery and one of several things I like about is the metal case for protection against damage.
http://www.tenergy.com/51060
a shorter but thicker battery. Wonder if that would work.1 -
I know this size fits in my Maestro and yes it charges in the Maesro from AC Size (LWH): 5.3 inches, 2.9 inches, 0.47 inches1
Thank you Howard. I'll convert those sizes to metric and see what will fit!! David G4NRT P.S. I think that America will go metric inch-by-inch!!0
I'll bring my "mic" to Yuma Hamfest (this weekend) and determine the max size possible.
It might be interesting to have an optional battery cover that allows a thicker battery to be used.
C U in Yuma0
They tried to in the 1970's but it failed because the lunatic fringe thought it was a Communist Plot to make it easier to invade the USA.2
Hey Howard,
Looking forward to meeting you in person..
Tim
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
