PTT does not key my PW1 amplifier
Bruce Elbert
Bruce Elbert Member ✭✭
edited July 2018 in SmartSDR for Windows
This is a new 6300 which is up and running with DDutil 3 and DAX to control the PW1 frequency and connect to PC software. But, it does not key over the PTT cable and TX 1. I checked the voltage on the PTT line and it reads about  3.5V DC constant, even as I push the MOX button on SmartSDR. I can key PTT on the PW1 by grounding the cable. I tried all of the recommended software settings in these posts. Is it a hardware issue or other? Thanks. 73, Bruce K6ZB
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    You need to enable the PTT Line in the startup screen
    AND you need to have DDUTIL set to OPERATE which activates that line
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited November 2016
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited July 2018
    Write a replyimage
