muting TX slice
Dave
I mute mine all the time when operating in digital modes. Once I'm setup and running I mute it so I don't have to listen to the tones. The audio is fed to the program via DAX.
Bill
VA3QB2 -
Dave I also mute audio 100% of the time when operating digital modes2
I mute the TX slice quite often when working split in any mode. I turn it on occasionally to check my TX frequency, but otherwise keep it quiet so I can concentrate on the RX frequency.
73, Ray, K9DUR
Yep, if you do any DXing, and the op is working split, most of us (oh, ok, I) will mute the TX slice and just watch signals in the panagaptor while listening to the DX station. And that's just one scenario where I mute the TX slice.2
I do the same - remembering that I still get a visual to watch for immerging signals on my TX frequency.
Steve
K9ZW
I work many DX pile ups and this discussion about muting the TX slice is quite interesting to me. Coming from a legacy radio background, it was normal to use the T-F button to peak at my transmit frequency to find the last station worked or a clear spot in the pileup. Of course is with the flex, the panafall combined with CW skimmer adds a new dimension to this usage pattern; however, I still feel the need to occasionally listen to my.transmit frequency. Of course, the obvious response is so what, just listen to both the DX station and your transmit frequency. This is of course acceptable in some/many situations but not all. This becomes problematic when the DX station is weak and the pileup is not well behaved (e.g. Continuous calling..etc). So what does all these say? Just stick with visual and abandon listening to my transmit frequency when the DX station is weak? Or do we need some analogous function to the T-F peak? In my personal opinion it would really help to have an analogous function. Something like a assignable button on the flex control to mute/unmute the audio from the tx slice. I am thinking one that you hold in to activate. It would essentially temporarily reverse the muted/unmuted state of the TX slice. So if the TX slice audio is already muted it would unmute it for as long as hold the button down. If the TX slice audio was not muted it would mute for as long as the button is pushed. Such a function would be something one might need in every pileup but would be extremely helpful in the situation I described above. For those that want to work purely visual, then no need to use this...it would be a purely optional function. In my mind flexibility is key...after all, flex is in the name of the radio0
I would like to use FlexControl to mute the TX slice. At the moment it is not possible. Would like to see that added to it.
As a serious DX-er I am keen on seeing this feature incorporated into a future SmartSDR release. What is the process for selecting and prioritizing the various "ideas" that come in through the community? Is there a roadmap that shows which new features are being targeted into which release?
Tim (N0TB)0 -
There used to be a very detailed Roadmap with dates
BUT the WHINERS killed the golden goose that laid the golden eggs...
So now everything is under wraps until it is released.
Frankly most of us would rather it be that way than initiate a return of the caustic whining....
- 370 Community Topics
- 628 The Flea Market
- 86 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 244 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
