SmartSDR TCP/IP API - "xmit" command - unexpected behaviour
IW7DMH, Enzo
IW7DMH, Enzo Member ✭✭
edited February 2017 in FLEX-6000 Signature Series
Hello,
during a test on my voice keyer I found the following (I suppose) problem: I sent a "xmit on" command while the radio was turned on, but no client was connected (SSDR off).
This caused and immediate transmit (MOX button enabled) as soon as I started SSDR.
Probably commands like "xmit" should be rejected by the radio when no client is connected.
Can you confirm this is the right beaviour? (My rig is a 6300)
73' Enzo
iw7dmh
  • Eric-KE5DTO
    This is indeed a bug as I just confirmed the behavior.  I have entered it as  issue #2990 in our tracking system.  Thanks for reporting this.
