1.6.17 HRD Log book slice B tracking
Ian1
Ian1 Member ✭✭
edited May 2020 in SmartSDR for Windows
Tried creating a TCP Port for Slice B no luck.
This is strictly for the Log Book Slice B function in the Radio is not in question.
Ian
  • Tim - W4TME
    edited March 2017
    If the third-party app doesn't support the Kenwood or SmartSDR CAT protocol over a TCP socket, this will never work.
  • Walt - KZ1F
    Walt - KZ1F Member ✭✭
    edited November 2016
    I am, if you are using the subscription version of HRD, open an issue with them. For $100/ yr or even $60, they should be receptive to your use case. Minimally they should explain how it works and when it can or why it can't work as you'd prefer.
  • Ian1
    Ian1 Member ✭✭
    edited May 2020
    Really they way HRD is setup for Flex they use a program called MiniDeluxe.
    It appears that in Mini Deluxe you can only select a single com port.
    It's interesting before 1.6.17 this use to work just fine for 2 slices.
    Ian
  • Barry N1EU
    Barry N1EU Member ✭✭
    edited February 2017
    Yes, it's not just HRD.  N1MM Logger also lost sliceB/vfoB functions in v1.6.  Flex is aware of it.
    73, Barry N1EU
