momentary jt65 signal drops
Dave Danforth
Member ✭
Recently my Flex 3000 on jt65 will show a fattening of the sig on panadaptor. This is accompanied by a reduction in vertical element of sig, power supply meter drops 6-9 amps and the power meter on the 3000 drops about 10 watts. The monitor tone has a weird "swish" sound at the time this happens.. Thoughts? Running powersdr 2.7.2
Could the power amp be folding back due to bad SWR?0
I have a web site with lots of info on this type problem . You might want to give this a look at a see if the answer is there.
http://w4wwj.org/JT65X.htm
73 Jim w4wwj
Could be a drop in the sound card audio as well to the F3K, causing a drop in rf.
Thx for comeback, Michael....the swr is fine. Thx again for info.
Going to spend some time there later today....wil apprise of results. Thx, Jim.
Thx, John...got me thinking since I am facing latency problems more lately as shown by the FlexRadio app....my other latency monitor however looks fine except for hardpage numbers being very high. Any thoughts on what this show?
How much memory have you got and how much is allocated to the swop file I think its called.......To speed things up, windows saves a lot of repetitive stuff to memory for quick access. Are you running other software at the same time which dont need to run excepting anti virus. Try removing any apps you have running on the task bar. Unless you have a super computer, you will need all the processor power you can get incl memory.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
