Question for Java Developers - Multiplatform GUI classes
Hello,
I did some progresses with my program and I want to show you the first significative result.
I rewrote the code of my previous remote cw keyer program transforming it in a remote control console for my next device. Now I have implemented the following features:
- 8 manual/automatic relay switch with embedded programming console (14 bands x 8 relays);
- rotator control console for Prosistel "D" (the only I had to test with);
- 2 hardware RS232 ports implementing 1.5 CAT protocol;
- remote cw keyer.
Here is the GUI I developed while it is running on the three most used operating systems (Windows 7, Mac OSX Yosemite, Linux Ubuntu 14.04-LTS).
About the cw keyer feature I am testing a sidetone generation system while SSDR is in remote mode. It is the first time I am using the java.sound APIs and I am wondering if I am on the right way or I can use a better library to do the job. There is a lot documentation on playing clips but far less about tone generation.
I had some clipping problems as you can see in the following video while I am working VP8STI DXpedition
https://www.youtube.com/watch?v=xYFYTc00xbg
Now let me thank Walt for his great advices! Mastering JavaFX isn't not so simple, but I am going on.
I hope the Flex Java APIs will be available as soon as possible.
73' Enzo
iw7dmh
We could maybe work something out on that, my friend.
Did you do straight Netty on those apps?0 -
BTW, Simply outstanding execution!!!0
Enzo, did you search java midi? Try kevinboone.net/javamidi.html0
Enzo, it just gets better and better! Very nice. I'm sure you will solve your issues.
james
Netty is on my to-do list. In the beginning I had some trobles with the subtle "Not On fx application thread" error, so I concentrated my efforts on the gui logic.
Actually my protocol is very simple, just 7-8 commands, and now I am using a simple parser thread.
I'll do some test with javamidi in next days.
Thank you very much.
Thank you James, nice to read you again. I can work on this project only during the we, so my progresses go on very slowly ...
JavaFx actually open an entire universe and I think it makes a lot of sense studing for it.
73' Enzo
iw7dmh
Ah, the other thing I want to point out to you, small steps to start, is SceneBuilder. The 2.0.2 source is available and Gluon is now supporting the ongoing dev of it. You app is graphically very busy. SceneBuilder will save you an immense amount of time and will not only wire a controller for you and wire in a Style sheet (CSS) to your controls so you can externally change the look and feel without touching code. The base stylesheet for javafx8 is Modena but you can subclass it with your own stylesheet. Yes, I long ago concluded using javafx8 is the only sane way to develop graphical software. I have been trying to convince certain people of that. So far, to no avail. I have not updated XPSLib since adding the data access objects, so it is still at 1.4.whatever. However, unlike flexlib, it works just fine with a radio at 1.6.whatever. If you are not already using it you'll like SceneBuilder.0
Yes, it is.
I developed two scenes using Scenebuilder and then I refined control's layout using CSS styles . This is really amazing for a desktop application.
I have also tested the whole deployment cycle using the Eclipse plugin. It seems really smart and powerful. No matter where you develop: after the build process you can deploy wherever you like.
And this is why I've been so, shall we say, passionate about FRS picking up the mantle of supporting SmartSDR for all platforms rather than people having to continually playing catchup with whatever FlexRadio decides they want to do every three months. Now, if I could charge what DogPark and Stu charge and even get but 200 people, much less 1,000) to take a completely portable (RUN IT ANYWHERE) SSDR facsimile, then sure I'd be happy to play follow the leader with FRS or, hire someone in India or China to play follow the leader with FRS while I maintain rights to the IP..hmm that precludes China then. As a consumer though, it's just easier if FRS does it...which they seem insistent on not doing. But, for free? I am not going to release it and support it for free.
But I am thrilled you are embracing the technology. I think it is the only sane way to develop RIAs. There are just too many people who, given a viable choice, would never use Windows.
But, hosting a 24x7x365 license server while doable is a pita to develop. I am not sure I could get a fail-safe vm from AWS for a year at three cents per hour. It works with Apple and Google (Android) because they know who you are and what device you are using. Microsoft, RH/Canonical, Raspberry Pi don't. I agree with Stu that the problem is not rocket science. It is also not trivial once you think it through.
Maybe I just lack a sufficient entrepreneurial spirit. (500 * $100 * 0.7). Hmmm, maybe I should do trailers.0 -
Hello,
in the end I have used the beads library (http://www.beadsproject.net/) that is most likely a wrapper for the native Java Sound Api I was using in my first attempt. With the beads library you have out of the box most commons wave generators, players of any kind and a very reliable enviroment for thread handling/synchronization.
Anyway tone generation is a matter of pc speed, audio sound card performance and cw speed. This actually means that you may experience bad delay if the mix of the three components is not enough for fast tone generation. I had good performance until 20wpm, but for more speed I still prefer the cw keyer sidetone generation. In this way I have a perfect timing until 35 wpm so I can consider this solution the only way to go.
At the moment my experiment is ended and I now I am able to control my little station from a remote place using a standalone device (no pc on the remote side) and do other things you can see in this video.
73'
Enzo
Very cool Enzo! Very cool indeed!0
Outstanding work! James0
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 175 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 218 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 286 Shack Infrastructure
- 201 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
https://www.youtube.com/watch?v=ZH9_hgTfbw8
