Dirty JT65 Transmit
Mark_WS7M
Member ✭✭✭
I seem to remember reading a few posts about dirty transmit signals, well tonight I got mine.
I had my 6500 running for probably a week without a restart. I have been working CW mostly trying to get the K5P and VP8 stations.
I went up to 40m LSB and did a few short QSO with the amp on. I switched to the provided radiosport profile and got good results.
I then decided to play some JT-65. The signal didn't look right and my computer speakers were making a little noise I wasn't used to hearing but a guy did come back. However when I called CW someone sent:
WS7M CHECK SIGNAL
So I did Ken's trick and did the xvrtr and full duplex and yes it was nasty. I played with DAX gain, nothing seemed to help. So I simply quit everything, remote depowered the radio, restarted it and now the signal is clean under the same exact configuration.
Interesting.
WS7M CHECK SIGNAL
Interesting.
interesting0
I have seen mine do this several times. It seems to be directly related to how long the radio has been on. It has only happened for me when the radio has been on for at lest 24 hours.
Mark,
Jon is correct. This is a pernicious little bug where the DAX signal becomes corrupted if DAX is running for a couple of days. Closing & re-starting DAX always fixes the problem. This is not unique to JT-65, but applies to all digital modes.
I am on the alpha team, but have not been able to determine a set of circumstances that causes it except for a random length of time - usually 2-3 days. Therefore, it is almost impossible to give any guidance to the developers to help them track it down.
73, Ray, K9DUR
I've also seen this when leaving my system on for days...since it's so convenient to have my radio in the back room and I can't hear it...it's a great problem to have.
You mentioned your DAX rx gain, I'm interested in what others have set for digital modes
My DAX rx gain is set to 30
AGC set to off, AGC-T at 430 -
Ray,
Thanks for your input. So the problem is most likely in DAX, not the radio? So my solution last night could have been a DAX restart?
Mike, on gain I found I had to set TX=36 to get the SmartSDR meter to read about -10 or so. I've worked a station that said this looked and sounded good. I generally set AGC off as well but I have not messed with AGC-T. I'll have to check that out.
This is one problem I see with JT65. While it is a fun mode to just click and work stations, the transmission packets are pretty limited and the turn around time is horrendous to find out if something made it, or not, or you have an issue.
Mark,
Yes, all you need to do is restart DAX.
73, Ray, K9DUR
I feel like a idiot as I can't find where to see these settings.
mind sending me clue via bill@w9ol.com?? pse et tu de w9ol.com
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
