6500 with VHF Xvtr and ThumbDV/Dstar
Steve Belcak
Is it possible to hv a VHF Xvtr connected and a ThumbDV plugged into a usb slot in the flex running/monitoring Dstar on Slice A while at same time operating 40 mtr cw on Slice B.....
Idea was to hv a slice monitor a local DSTAR repeater but still be operating the HF bands?
How about HF DSTAR running on one slice and 40 cw on another?
Does anyone have any experience with this?
Steve
Steve
Unfortunately since the 6300 and 6500 have one receiving when using the transverter you will only be able to use it and the HF is unavailable. The 6700 with two receivers would provide what you want for using the transverter and HF at the same time.
You should be able to use the D-Star with the transverter.
I run a DEMI VHF with my 6500 and what David says is true. When i bring up a HF slice, the receive antenna on the transverter automatically switches to the HF receive antenna. If i adjust the VHF back to the proper antenna, it also changes the HF slice to that antenna.0
Thank You....0
There is a way to do this, but it's a bit of a compromise. Your transverter needs a separate receive output, and you need a separate HF receive antenna (I use a Wellbrook loop). Your HF tx antenna connects to Ant 1, your transverter drive output from the Flex to transverter tx input, and you combine the HF rx antenna and transverter rx out onto the RXA socket. The downside is, if your transverter is say a 10M IF, you'll see both 28MHz and 10M signals on the transverter and 10M bands.
However, if you're only interested in a spot frequency for the DSTAR repeater, you may well get away with it.I use my 6500 like this occasionally, and it works well - but 10M is usually pretty quiet here!
Keith
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
