Anyone else having trouble retaining the Calibration Offset Value?
Dick / KC9YRA
Dick / KC9YRA Member ✭✭
edited April 2020 in SmartSDR for Windows
Anyone else having trouble retaining the Calibration Offset Value on a Flex 6500 (No GPS) with SSDR 1.6.17.  My offset value is -1189 @ 15 MHz.  Reverts to 0 value after I do a radio shutdown and restart.  I did a Factory Reset.  Value still not retained.  The calibration routine works ok, the value is not saved.  Value was retained with SSDR 1.5.1.  What am I missing?
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited January 2016
    Yes, I just did the same thing and noticed zero offset when I turned the radio off and on again.
    My offset was -318 Hz. at 10 MHz. and returned to zero.
    Jim, K6QE
  • [Deleted User]
    edited April 2020
    Are all the 6500's like that or just a few with the problem??
  • Jim Gilliam
    edited January 2016
    I can only speak for mine.
  • Walt
    Walt Member ✭✭
    edited July 2017
    Mine does not save after power-off  - its a 6500 - hope Tim comments soon . .   or time to open a help deck ticket
    no joy . . .
  • [Deleted User]
    edited April 2020
    And of course it will be addressed in the next update..
  • [Deleted User]
    edited April 2020
    How can they test this software for the amount of time they did and have problems like this?? Nobody noticed it wasn't retaining calibration??
  • Dan -- KC4GO
    Dan -- KC4GO Member ✭✭
    edited May 2019
    By power cycle I assume it's stop SmartSDR then push the power button to turn the radio off then push the power button to turn it on. If that's the case my 6500 kept it's calibration.
    At 15 MHz it's -625 and according to Fldigi it's within a couple of cycles. (No GPS)
    Sn 4714-4055-6500-1842  Purchased End of Nov 2014
    Note: I power cycled as above and disconnected the DC input  6500 kept it's calibration.
              I have done a factory reset  6500 kept it's calibration.
    So I guess to answer  Steve no it's not all 6500
    @ Steve I did test calibration and because of this thread I tested it again.
    Regards & 73'
    Dan--KC4GO
  • Jay Nation
    Jay Nation Member ✭✭
    edited August 2016
    Just a dumb guess, but maybe the radio only writes the calibration value to storage during Reboot/Power down. It might also only read it from the ROM storage during Power up/Calibration. With 1.6.14 perhaps the only way to store the value is to, set the value then Power Off/Power On cycle the radio.
    Just a dumb guess, because I have the GPSDO,
    so I don't have any offset/correction to worry about.
    Also, has anyone tried Saving the Global Profile immediately after filling in the offset, that might write the value to the radio without requiring a power cycle. The Global profile is stored in the radio.
    73, Jay - NO5J
  • Tim - W4TME
    edited March 2017
    Your radio believes it has a GPSDO installed which is why the offset is reverting back to 0.
    To fix, do the following:
    Start SmartSDR and connect to your radio.
    From the Settings menu, select the Radio Setup->GPS tab.
    Click on the Uninstall button.
    Close SmartSDR
    Power cycle the radio
    From the Settings menu, select the Radio Setup->Receive tab
    Run a frequency calibration
    Close SmartSDR
    You should see the previous offset value now.
  • Walt
    Walt Member ✭✭
    edited July 2017
    Tim just sent me these instructions 5 min. after I sent a helpdesk ticket.
    Followed the procedure and all is well.
    Thanks Tim !!!
    Lots of Joy now . . . . .
  • Jim Gilliam
    edited January 2016
    Ditto, here...Thanks Mr. Tim!
    Jim, K6QE
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited December 2016
    From Tim's instructions it looks like they didn't miss it, all is good. Just a thing of understanding how things should work.
  • Dick / KC9YRA
    edited January 2016
    Thanks Tim!
    This resolved the calibration offset save problem on my Flex-6500 also
    73 - KC9YRA
  • Jim Gilliam
    edited March 2017
    Out of curiosity, was the radio calibrated once the calibration procedure was initiated even though it showed "0" offset or did it lose its calibration after the power recycle?
    Jim, K6QE
  • Dick / KC9YRA
    edited January 2016
    Jim
    Yes My Flex-6500 would calibrate to less than 1 hz,  Checked with fldigi frequency analysis method.  Held calibration very well over months.
    **** - KC9YRA
  • Tim - W4TME
    No, it was not on frequency after the power cycle.  If the offset was showing "0" and the XO needed a different offset, the radio would be off frequency.
  • [Deleted User]
    edited April 2020
    Well that was a simple fix. Thanks Dr. Tim
