Smart SDR 1.6 with 2 instances of WSJT-X
Douglas Reece
Member ✭
Has anyone successfully configured 2 instances of WSJT-X to run on slices A and B under SmartSDR 1.6.17?
Yes the key is to run wsjtx.exe with a different --rig-name parameter for each slice. This creates a separate configuration for each instance and create a CAT port for slice B.
i.e.
wsjtx --rig-name=slice_a
wsjtx --rig-name=slice_b
you can then configure each instance separately point one at your slice a CAT port and the other at the slice b one.0 -
It's working now. Thank you so much!
Doug (AK4AO)
Sure...I had to put a send copy of the decoder software into another directory...I placed another copy in C: and my computer ran both simultaneously. Daniel W3DCB0
It works really well. I have even managed to have two simultaneous QSOs (on different bands) using my RX loop and FDX mode, transmitting odd minutes on one slice and even on the other!! No need to have two separate copies of WSJT-X.0
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
