Got DM780 working with the Flex Winkeyer emulator.
Jerry Wilk
Got Winkeyer and DM780 working with the Flex emulator using DDutil. Also, using CW Skimmer in parallel since DM780 cw decoding is marginal at best. Had to try several SmartCat com ports but eventually found one that worked. Hats off to Flex Radio. AA7SN
You're absolutely right, Jerry! DM780 is only useable on machine-generated CW code,
and even then misses a lot of characters. fldigi is better, CWGet is a lot better, but CW
Skimmer tops them all, IMHO.
CW decoding is one of the most difficult problems for a programmer, as there are a lot
of different ways to create CW. Different spacing, length of characters, lenghth of dots
and dashes, machines, bugs, straight keys... I can decode CW up to 20 wpm, but only
for a relatively short time, for monitoring purposes I use CW Skimmer. I need to
practice more ;-)
- 384 Community Topics
- 650 The Flea Market
- 150 SmartSDR+
- 263 SmartSDR CAT
- 288 FLEX-8000 Signature Series
- 962 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 802 Peripherals & Station Integration
- 142 Amateur Radio Interests
