Smart S-meter v1.6 available
Hi,
new S-meter for SmartSDR v1.6 is available for free download at: http://woodboxradio.com/freeware.html
Thanks to new CAT you can run multiple S-meter as many the slices are.
73 Beppe
ik3vig
woodboxradio.com
Welcome!
«1
  • Member ✭✭
    edited April 2018
    Tnx  :-)
  • Member ✭✭
    edited January 2016
    Thank you Beppe
    Regards G4BIM
  • Member ✭✭
    edited March 2018
    Tested and working thanks Beppe
    Dan--KC4GO
  • Member
    edited August 2017
    Very nice Beppe! Thanks so much for the large S-Meter. I have vision issues and now I can read signal strengths. Thanks again! Dave K4EET
  • Member ✭✭
    edited January 2017
    Thanks, really appreciate this. Joe WD5Y
  • Member ✭✭
    edited January 2017
    Downloaded, will install it this evening! Many thanks
  • Member ✭✭
    edited March 2017
    Cool, I'll have to check this out.
  • Member ✭✭
    edited July 2018
    Thanks you very much Beppe!
    "bellissimo" Works perfect. I like the ability to adjust the AVG Smeter and the Peak Hold feature!
    John
    KC2QMA
  • Member ✭✭
    edited June 2017
  • Member ✭✭✭
    edited June 2020
    Works very nicely!  Thanks.
    I have it running on two slices.
    Adjustable hold and averaging makes it very nice.
    Ken - NM9P
  • Member ✭✭
    edited May 2020
    Nice job Beppe... TNX
  • Member ✭✭✭
    edited January 2016
    Thank you very much, Beppe.  Your art work for Flex and Perseus is absolutely stunning.  The three dimensional effect and the shadows make a very nice image.
  • Member ✭✭
    edited April 2017
    Wow these are very sharp!  Im gonna check these out.  Looks like great work!
  • Member ✭✭
    edited September 2017
    good job :) 2 slice 2 s-meter
  • Member ✭✭
    edited January 2017
    Great update Beppe!  Thanks for quick response to V1.6 changes.  Donation is on the way!
  • Member ✭✭
    edited May 2016
    bellissimo!  I mean seriously!
  • Member ✭✭
    edited January 2017
    Easy to set up and running great. Many thanks
  • Member ✭✭
    edited May 2016
    It might not be compatible with my setup. It works FB, but the Meter face is sort of tiled looking on the computer screen. Bummer!
  • Member ✭✭
    edited October 2018
    Thank you Beppe!
    I installed this for the first time and had no trouble. Looks and works great.
    Is it possible to add an argument to specify the COM port so I can create a shortcut like
    "Smart S-Meter V16.exe 8"
    for COM8 and other ports for additional slices?
    It would be easier to startup than having to reconfigure for more than one meter each time.
    Danny
    K2DMS
  • Member ✭✭
    edited January 2019
    Jim  WU7G
    Help!!  I have a meter then pieces of 3 other meters. Example the working meter to the right half of a meter, below part of the top of a meter, and lower right is the top left corner of a meter. What did I **** up?
    Jim
  • Member ✭✭
    edited May 2016
    Same here. It does work great on my Windows 10 machine where I'm at 1440 by 900. Its my Mac running bootcamp and Windows 7 where I have the same problem you do. I'm on the OSX side of my Mac and will report the resolution when I reboot.
  • Member ✭✭
    edited May 2016
    As suspected, my Windows 7 in bootcamp is using my iMac monitor at 1920 By 1080.
    I've not had luck with changing the display size yet.Shows the same amount of stuff, but just takes up less real estate on the screen. What I want to do I now need to log off before seeing if it works.
    I'll let you know if I have any luck.
  • Member ✭✭
    edited May 2016
    Eureka! Try this Jim:
    When I tried making my icons smaller - they were at 125 percent -  I changed them to 100 percent. I had to log out. Logging back in, The icons were smaller, as well as the windows. But the S-Meter is now juuuuussst right. Beautiful.
    Right click - Screen resolution - make text and other items larger or smaller, then select 100 percent.
    Now my biggest dilemma is modern or classic look. 8^)
  • Member ✭✭
    edited December 2016
    That did it, however I changed mine from 125 to 150 and that worked. If you don't mind, one other question. On my 6300 I had 2 S-meters working off slice A but none working for slice B. Any ideas?
  • Member ✭✭
    You have to have a CAT port for each slice, then a meter for each CAT port.
    I also have Auto Switch to TX turned off so that they stay where they are.
  • Member
    edited May 2020
    For those who like to keep their thoroughly modern radios with old school controls we proudly announce the availability Smart Coils v1.6 click and drag plug in coils slice band switching.
    *Built in five minute band change delay to keep it realistic to the period.
  • Member ✭✭✭
    :-)  Looks like a GDO coil set!
  • Member ✭✭
    edited October 2018
    Very nice. Thank you.   Dan
  • Member ✭✭
    Thanks much, I'll make the changes...
    73 Jim
    WU7G
  • Member
    edited January 2016
    Danny, thanks for comments and usefull suggestion.
    Stay tuned........ :-)
