Smart S-meter v1.6 available
Beppe IK3VIG
Hi,
new S-meter for SmartSDR v1.6 is available for free download at: http://woodboxradio.com/freeware.html
Thanks to new CAT you can run multiple S-meter as many the slices are.
73 Beppe
ik3vig
woodboxradio.com
73 Beppe
ik3vig
woodboxradio.com
12
Tnx :-)
Thank you Beppe
Regards G4BIM
Tested and working thanks Beppe
Dan--KC4GO0 -
Very nice Beppe! Thanks so much for the large S-Meter. I have vision issues and now I can read signal strengths. Thanks again! Dave K4EET0
Thanks, really appreciate this. Joe WD5Y0
Downloaded, will install it this evening! Many thanks
Cool, I'll have to check this out.0
Thanks you very much Beppe!
"bellissimo" Works perfect. I like the ability to adjust the AVG Smeter and the Peak Hold feature!
John
KC2QMA0 -
Works very nicely! Thanks.
I have it running on two slices.
Adjustable hold and averaging makes it very nice.
Ken - NM9P0 -
Nice job Beppe... TNX
Thank you very much, Beppe. Your art work for Flex and Perseus is absolutely stunning. The three dimensional effect and the shadows make a very nice image.
Wow these are very sharp! Im gonna check these out. Looks like great work!
good job
2 slice 2 s-meter
Great update Beppe! Thanks for quick response to V1.6 changes. Donation is on the way!1
bellissimo! I mean seriously!
Easy to set up and running great. Many thanks
It might not be compatible with my setup. It works FB, but the Meter face is sort of tiled looking on the computer screen. Bummer!0
Thank you Beppe!
I installed this for the first time and had no trouble. Looks and works great.
Is it possible to add an argument to specify the COM port so I can create a shortcut like
"Smart S-Meter V16.exe 8"
for COM8 and other ports for additional slices?
It would be easier to startup than having to reconfigure for more than one meter each time.
Danny
K2DMS0 -
Jim WU7G
Help!! I have a meter then pieces of 3 other meters. Example the working meter to the right half of a meter, below part of the top of a meter, and lower right is the top left corner of a meter. What did I **** up?
Jim
Same here. It does work great on my Windows 10 machine where I'm at 1440 by 900. Its my Mac running bootcamp and Windows 7 where I have the same problem you do. I'm on the OSX side of my Mac and will report the resolution when I reboot.0
As suspected, my Windows 7 in bootcamp is using my iMac monitor at 1920 By 1080.
I've not had luck with changing the display size yet.Shows the same amount of stuff, but just takes up less real estate on the screen. What I want to do I now need to log off before seeing if it works.
I'll let you know if I have any luck.
Eureka! Try this Jim:
When I tried making my icons smaller - they were at 125 percent - I changed them to 100 percent. I had to log out. Logging back in, The icons were smaller, as well as the windows. But the S-Meter is now juuuuussst right. Beautiful.
Right click - Screen resolution - make text and other items larger or smaller, then select 100 percent.
Now my biggest dilemma is modern or classic look. 8^)
That did it, however I changed mine from 125 to 150 and that worked. If you don't mind, one other question. On my 6300 I had 2 S-meters working off slice A but none working for slice B. Any ideas?
You have to have a CAT port for each slice, then a meter for each CAT port.
I also have Auto Switch to TX turned off so that they stay where they are.0 -
For those who like to keep their thoroughly modern radios with old school controls we proudly announce the availability Smart Coils v1.6 click and drag plug in coils slice band switching.
*Built in five minute band change delay to keep it realistic to the period.1 -
:-) Looks like a GDO coil set!
Very nice. Thank you. Dan0
Thanks much, I'll make the changes...
73 Jim
WU7G
Danny, thanks for comments and usefull suggestion.
Stay tuned........ :-)1
