RX A and bypass of ATU
1) Watch your preamp indicator when you do it and check if there is any change. There may be something glitchy happening there. 2). How close is your pixel loop to you other antenna? Could the tuning of the transmit antenna be detuning your loop or interacting with it in some way. Just a couple stabs in the dark. Ken - NM9P0
Hi Ken,
Thanks for the reply. I just double checked, the indicated state of the preamp does not change. I can observe the noise floor drop just by bypassing the ATU, no tuning needs to take place.
Again, thanks for the suggestions.
https://www.youtube.com/watch?v=llfK7yAcMLg
Made a video of the issue. I mouse over the signal level so you can see that it is at -86.9 or so. I then select the ATU button to bypass the ATU. You can see the change in the noise level, I mouse back over the signal level and it indicates -96. That is almost a 10 dB change. This indicates to me that the RX-A input is in circuit with the ATU.0 -
I notice that when you turn the atu off, that the noise level drops, but that three or four signals stay the same and now come up out of the noise. This looks more like there is a noise source being generated when the atu is turned on. It would be easier to tell if there was sound with the video. Do you get this on other bands? If so, is the noise shift the same? It could be a hardware issue either inside or outside the rig. I would recommend opening a help desk ticket and see if they can help you sort it out. Ken - NM9P0
Another question.... If you have your safety switches installed on the pixel, Is there any change on the switching voltage going to it as you turn atu off and on? Do you have ferrite beads on the power and safety relay leads?0
Just a thought, could the antenna tuner be acting as some sort of preselector, similar to the "antenna trimmer" control on legacy receivers? I have a Pixel loop and I'm going to try this tonight.
Hi Ken,
Those signals you see come up out of the noise floor are valid JT-65 / JT-9 signals, that is what troubles me about this issue. It truly affects what stations can be heard or copied. I checked the switching voltage, no change. I do not have any ferrites on the power lead or the switching signal. On the video I am bypassing the ATU not activating it, so I doubt if it is RF getting into something. Thanks again for your reply
Hi Robert,
I would appreciate your findings from your pixel. it appears to me that the ATU is in the RF path for RX-A, I'm not sure why that would be from a design stand point. I am going to test with another antenna on the RX-A port. I think it will occur regardless of antenna type on the RX-A port.
It does act as a preselector. It is in both the RX and TX signal path.0
The ATU does act as a preselector. It is in both the RX and TX signal path.
Hi Tim,
Thanks for the reply. As you can see the affect of the ATU (preselector) on RX-A is pretty dramatic. Any possibilities of removing it from the RX-A path on future loads? Seems like it would be possible since you can affectively remove it by going into bypass. Maybe a future option setting - "Automatic Bypass on Receive"
According to the signal flow diagrams in section 12 (page 40) of the current hardware manual, the ATU cannot be in the RX-A path. Is the manual wrong?
I know this discussion was for the 6500, but certainly with the 6700, a single ATU cannot be in both RX-A and RX-B paths. I would not expect the 6500 signal path to be that different.
73, Bob, N7ZO0 -
Bob,
You make an excellent point. According to the signal flow diagram, the ATU should be out of the picture when RX-A is selected for receive. This is how I thought it worked.
I just got home and tried it. I am unable to duplicate this problem. I'm running a 6500, Pixel Loop and 1.6.17
Perhaps a factory reset is in order. Something else to consider. Like all of us, you imported your profiles. Have you tweaked and resaved at least one default set of profiles under the new version? I would think that at least the GLOBAL profile might handle some features slightly different.
Thanks Robert, I have tried a factory reset, no change. I think at this point I will open a help desk ticket.0
I have a Wellbrook loop on RX-A in my 6500 and notice no difference in S meter reading whether tuned or bypass
73 W9OY-1 -
It is in the signal path if the RX antenna is the same as the TX. For RX-A/RX-B is is not.0
A 10 dB drop is way more than the insertion loss for the ATU, but since you are using RX-A, the ATU is not in the signal path on RX. It is only in the signal path when the RX antenna is one of the ANT-x antennas. I misread your statement above. Sorry about that.
Opening a HD ticket is the right course of action at this point so we can figure out what is happening.0 -
Try a different ant on RX-A to confirm if its the radio or the antenna
73 W9OY0 -
Lee,
Thanks for your reply. Just tried a different antenna and I still see the issue. It does not appear to be as pronounced but the substitute antenna is not as quiet as the Pixel. I have opened a help desk ticket and received a reply from Dudley, I am confident He will get it sorted out. I will report back the findings.
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
