Smart S-meter v1.6 available
Beppe IK3VIG
Beppe IK3VIG Member
Hi,
new S-meter for SmartSDR v1.6 is available for free download at: http://woodboxradio.com/freeware.html
Thanks to new CAT you can run multiple S-meter as many the slices are.
73 Beppe
ik3vig
woodboxradio.com
«1
  • ON5AM
    ON5AM Member ✭✭
    edited April 2018
    Tnx  :-)
  • Peter Bentley
    Peter Bentley Member ✭✭
    edited January 2016
    Thank you Beppe
    Regards G4BIM
  • Dan -- KC4GO
    Dan -- KC4GO Member ✭✭
    edited March 2018
    Tested and working thanks Beppe
    Dan--KC4GO
  • Wheelin Rev
    Wheelin Rev Member
    edited August 2017
    Very nice Beppe! Thanks so much for the large S-Meter. I have vision issues and now I can read signal strengths. Thanks again! Dave K4EET
  • Joe WD5Y
    Joe WD5Y Member ✭✭
    edited January 2017
    Thanks, really appreciate this. Joe WD5Y
  • WA2SQQ
    WA2SQQ Member ✭✭
    edited January 2017
    Downloaded, will install it this evening! Many thanks
  • rfoust
    rfoust Member ✭✭
    edited March 2017
    Cool, I'll have to check this out.
  • KC2QMA_John
    KC2QMA_John Member ✭✭
    edited July 2018
    Thanks you very much Beppe!
    "bellissimo" Works perfect. I like the ability to adjust the AVG Smeter and the Peak Hold feature!
    John
    KC2QMA
  • Ross - K9COX
    Ross - K9COX Member ✭✭
    edited June 2017
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    Works very nicely!  Thanks.
    I have it running on two slices.
    Adjustable hold and averaging makes it very nice.
    Ken - NM9P
  •   VE6KWA
    VE6KWA Member ✭✭
    edited May 2020
    Nice job Beppe... TNX
  • Steve W6SDM
    Steve W6SDM Member ✭✭✭
    edited January 2016
    Thank you very much, Beppe.  Your art work for Flex and Perseus is absolutely stunning.  The three dimensional effect and the shadows make a very nice image.
  • ctate243
    ctate243 Member ✭✭
    edited April 2017
    Wow these are very sharp!  Im gonna check these out.  Looks like great work!
  • Jean Drolet
    Jean Drolet Member ✭✭
    edited September 2017
    good job :) 2 slice 2 s-meter
  • Brian_W9HLQ
    Brian_W9HLQ Member ✭✭
    edited January 2017
    Great update Beppe!  Thanks for quick response to V1.6 changes.  Donation is on the way!
  • Michael Coslo
    Michael Coslo Member ✭✭
    edited May 2016
    bellissimo!  I mean seriously!
  • WA2SQQ
    WA2SQQ Member ✭✭
    edited January 2017
    Easy to set up and running great. Many thanks
  • Michael Coslo
    edited May 2016
    It might not be compatible with my setup. It works FB, but the Meter face is sort of tiled looking on the computer screen. Bummer!
  • K5CG
    K5CG Member ✭✭
    edited October 2018
    Thank you Beppe!
    I installed this for the first time and had no trouble. Looks and works great.
    Is it possible to add an argument to specify the COM port so I can create a shortcut like
    "Smart S-Meter V16.exe 8"
    for COM8 and other ports for additional slices?
    It would be easier to startup than having to reconfigure for more than one meter each time.
    Danny
    K2DMS
  • Jim Best
    Jim Best Member ✭✭
    edited January 2019
    Jim  WU7G
    Help!!  I have a meter then pieces of 3 other meters. Example the working meter to the right half of a meter, below part of the top of a meter, and lower right is the top left corner of a meter. What did I **** up?
    Jim
  • Michael Coslo
    edited May 2016
    Same here. It does work great on my Windows 10 machine where I'm at 1440 by 900. Its my Mac running bootcamp and Windows 7 where I have the same problem you do. I'm on the OSX side of my Mac and will report the resolution when I reboot.
  • Michael Coslo
    edited May 2016
    As suspected, my Windows 7 in bootcamp is using my iMac monitor at 1920 By 1080.
    I've not had luck with changing the display size yet.Shows the same amount of stuff, but just takes up less real estate on the screen. What I want to do I now need to log off before seeing if it works.
    I'll let you know if I have any luck.
  • Michael Coslo
    edited May 2016
    Eureka! Try this Jim:
    When I tried making my icons smaller - they were at 125 percent -  I changed them to 100 percent. I had to log out. Logging back in, The icons were smaller, as well as the windows. But the S-Meter is now juuuuussst right. Beautiful.
    Right click - Screen resolution - make text and other items larger or smaller, then select 100 percent.
    Now my biggest dilemma is modern or classic look. 8^)
  • Jim Best
    Jim Best Member ✭✭
    edited December 2016
    That did it, however I changed mine from 125 to 150 and that worked. If you don't mind, one other question. On my 6300 I had 2 S-meters working off slice A but none working for slice B. Any ideas?
  • K5CG
    K5CG Member ✭✭
    You have to have a CAT port for each slice, then a meter for each CAT port.
    I also have Auto Switch to TX turned off so that they stay where they are.
  • Drax
    Drax Member
    edited May 2020
    For those who like to keep their thoroughly modern radios with old school controls we proudly announce the availability Smart Coils v1.6 click and drag plug in coils slice band switching.
    *Built in five minute band change delay to keep it realistic to the period.
  • k3Tim
    k3Tim Member ✭✭✭
    :-)  Looks like a GDO coil set!
  • KM6CQ - Dan
    KM6CQ - Dan Member ✭✭
    edited October 2018
    Very nice. Thank you.   Dan
  • Jim Best
    Jim Best Member ✭✭
    Thanks much, I'll make the changes...
    73 Jim
    WU7G
  • Beppe IK3VIG
    Beppe IK3VIG Member
    edited January 2016
    Danny, thanks for comments and usefull suggestion.
    Stay tuned........ :-)
