The mode "Expand" for view SmartSDR
R2AGG
Hello dear FlexRadio! My Radio is Flex 6500. My software is SmartSDR 1.6.17 There is one comment on the appearance of the interface in the mode "Open the window". The interface is not fully opened and can not be deployed manually. In the mode "Expand" interface SmartSDR opens to full screen. This is on any screen resolutions. In other programs, such problems do not see. - Another note on the white **** at the top of the interface. - The window "Profiles Manager" is needed fixing in height. For examples put pictures.
Best 73! Mikhail R2AGG
Best 73! Mikhail R2AGG 0
I've reported both of these issues prior as Alpha defects. They are on file still for investigation.1
Mikhail on the Profiles Manager window just grab the bottom of the window with the mouse and adjust it!
Gary, he's trying to say that the internal window should scale when you resize it, and it should. If resizing wasn't intended, the ability to resize it should be disabled. It's a bug.1
Another case of opening my mouth and removing all doubt!! oh well I will just use the excuse that I am old....it always works!1
- 197 SmartSDR+
- 322 Shack Infrastructure
- 227 Networking
