Commander dx suite ssdr 1.6
About to upgrade to 1.6 whilst on a day off work today - using dx suite here and someone on dx suite reflector has reported issues with cat connection with dx suite and 1.6. Can someone please confirm whether they have 1.6 working with dx suite Commander? The author of dx suite is not aware of any issues but is still on 1.5 himself. I moved my logging onto dx suite due to the better integration with flex api and will delay moving onto 1.6 today if its not going to work with dx suite. I would have hoped that someone on the ssdr 1.6 testing team would be using dx suite and would have shouted to the author of dx suite if there were issues? I have read the new ssdr manual and the upgrade instructions a couple of times so now ready to try 1.6 today - if its working ok for someone with dx suite that would suggest just a set up issue and i can then proceed to work through the upgrade and careful set up of the new cat and dax on all my third party software like dx suite n1mmplus and wsjt 73 Steve Gw0gei / gw9J
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    Steve don't worry
    DXLabssuite in use with my F6700 from beginning(July 2013), no issues at ALL,
    after upgrade on 1.6.17 - all works FINE
    Connection Commander<->F6700 via IP
  • RoyS
    RoyS Member ✭✭
    edited December 2019
    Steve,
    I am running the DX Suite in Win 10 with Flex 1.6.17. I have no issues with the software.
    Roy
  • allenfr
    allenfr Member
    edited January 2016
    Using both on windows 10 and having no problems. Install was quick and flawless.
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭✭
    edited June 2020
    works fine, even on Windown 10
    Jim
    WU5E
  • Steve Gw0gei
    Steve Gw0gei Member ✭✭
    edited January 2016
    Thanks guys for your relies - that confirms to me it's probably a user issue in set up and I can therefore safely proceed to upgrade to 1.6 on w7 and carefully go through the steps with new cat and dax here with dx suite. Having moved over in recent two months to dx suite and got most of it working on the basics I didn't want to have to go back to logger32 and traditional cat Kenwood interface after enjoying the API interface in commander for last two months. I have delayed going onto 1.6 due to working full time and wanting to do the upgrade carefully at a time when I had time to do it! First I need to back up the few profiles I have set up in 1.5.1 7 and ensure that my windows 7 is up to date - it was not downloading windows updates this morning so going to go back to that later today as having read the docs I understand some have had issues if their windows is not up to date. I have Windows auto updates switched off as its a killer when it decides to auto download and update in the middle of a contest hi hi. I want to get everything set up properly to time with my 6500 post this major upgrade, and then if I decide to proceed to buy a 6700 next month it should be easier to do the hardware upgrade as ssdr will already be set up well in 1.6 Thanks for the reassurance - all my previous ssdr upgrades have gone well so hopefully this one will too. 73 Steve gw0gei / gw9J
  • Ed  KC9JBU
    Ed KC9JBU Member ✭✭
    edited December 2016
    I am using DxSuite WW for digital and can't get PTT to work. Can't find right DAX settings. Commander finds my Flex-6300 on EtherNet and controls radio ok. Could use some Elmer type help here. 73 Ed KC9JBU
  • Sergey R5AU
    edited April 2017
    Ed, you should have get PTT control  with DX WW in case you Commander works fine and with selection
  • Ed  KC9JBU
    Ed KC9JBU Member ✭✭
    That is the setting I have always used. I can't seem to find the right sound card settings. I see the DAX RX1 and it receives ok but I can't find the right DAX for TX. Maybe I don't have DAX set up correctly. What are your sound card settings?
  • Sergey R5AU
    edited April 2017
    Ed, sorry i am not using DX WW for digi due different reasons, however
    some time before i did it and i think this can help to you :
    https://www.youtube.com/watch?v=lcb5QGoo_Nc
    and
    https://community.flexradio.com/flexradio/topics/dax_devices
    with SSDR version 1.5 and below you should use the same DAX pair like
    RX DAX 1  and TX DAX 1  or RX DAX 2 and TX DAX 2
    for now in 1.6 it should be like:
    RX DAX 2 and TX DAX 1
  • Steve WS5W
    Steve WS5W Member ✭✭
    edited April 2020
    Looks like I am late to the party but no problems with DXLabs
    Steve Jones
    WS5W
  • Reggie-k6xr
    Reggie-k6xr Member ✭✭
    edited April 2020
    Anyone running DXLabs on dual monitors (SSDR on one and DXL on the other) with a Mac/parallels/win10?
    How to do it?
  • ctate243
    ctate243 Member ✭✭
    edited April 2017
    Works fine..  However there was a slight burp during initial install where it was not picking up the telemetry from the flex.  A full system reboot and it fired right up.  There have been reports that you have to specify the IP and port number to get it to connect for the first time, but once done it fires right up.
  • Sergey R5AU
    edited January 2016
    Not yet Reggie, for the moment 27 inch is enough for me  :-)
  • W5XZ - dan
    W5XZ - dan Member ✭✭
    edited June 2019
    http://www.dxlabsuite.com/dxlabwiki/FlexSignature
    worked for me, with dave's guidance...73
  • Ed  KC9JBU
    Ed KC9JBU Member ✭✭
    Thanks for advice. Problem found. It was corrupt DAX TR driver. Did an uninstall/reinstall of driver (after I found it) and all is well now. 73 ED KC9JBU
  • Dave AA6YQ
    Dave AA6YQ Member ✭✭
    edited July 2018
    I installed SmartSDR 1.6.17 on my 6500 today, made a few PSK and RTTY QSOs, and am pleased to report that no changes in DXLab support are required.
    The names of the virtual soundcards created by DAX have changed, so it was necessary to select the correct  Reception and Transmission virtual  soundcards on the Soundcard tab of WinWarbler's Configuration window, and on the Soundcard tab of WinWarbler's MultiRadio window. The macros I use to switch between single RTTY signal reception and dual RTTY signal reception employ <digirxsound:> commands, which also had to be updated to specify the new DAX virtual soundcard names.
               Dave, AA6YQ
  • Bill-W9OL
    Bill-W9OL Member ✭✭
    edited October 2016
    Steve, actually I use 3 monitors, all 27". (old eyes) and I most certainly have SmarSDR on monitor 1, and DXLabs applets intespersed around the other two monitors. There was no rhyme or reason for the placements other what window would fit where.  So I selected the DXL program that would fit in the space available on that monitor. Obviously I can mouse left-right with no problems. With surplus monitors being so cheap these days, the only issue is getting a video card that can support them. Mine had 2 vga? and 1 HDMI port.
