Remote Power On Switching?
Roger Thompson AD5T
The 6000 series hardware manual calls for shorting the remote power on center pin to ground to power up the radio, a pin that measures about 3.3 volts DC when open. I see discussions about pulling this pin to ground using a relay, but am curious if anyone has successfully used an optoisolator like a 4N25 or an open collector transistor switch?
I'll bet if those two transistor devices you mentioned don't put down far enough to cause the remote power to turn on a FET 2N7000 will work just fine, the 2N7000 FET junction pull down to ground with a lot less resistance in the gate then a transistor.
The FET doesn't require any more components then a open collector transistor depending on what your using to use to switch the device from HI to LOW if it happens to be inverted then it will require 2 devices and a pull up resistor just like a transistor.
73's
Bret
WX7Y
Hello Roger, in my last project I am using a 4N35 with success. I drive it using a Arduino Due digital pin through a 220 ohm resistor. In the same project I use another 4n35 to key the rig using the accessory port. It is very fast and totally silent. 73' Enzo iw7dmh0
From teh 4N25 datasheet, the Collector to Emitter saturated (CEsat) will be less than 0.20 Volts. This should easily control the 3.3V-DC input, pulling it low. The drive current of the LED (50 mA) should be noted.
Good Luck,
k3Tim
Just FYI,
I want to highlight the Orion G3NA solid state relay.
I am using it for my remote AC switch and I can drive it using a straight output Arduino port (@5V).
G3NA relays are rated for different input voltages (5-24VDC) and for different output loads (5 to 90A @ 24-240VAC) .
They are used for a lot of domotic applications and it seems they are very reliable.
73' Enzo
iw7dmh
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 329 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 770 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
