New COM philosophy
iz7auh
Member ✭✭✭
I would like to ask a question to the staff, personally own a UltraBeam and an amplifier expert 1.3k necessotabo therefore both are connected to the CAT with the 1.5 version lrecedente they tuned in to all the slice just abilitavo TX on the slice you want by using a single COM now this has become impossible because now there is close correlation COM slice this seems like a step back or there is a way and I have not realized? thank you
Frank if i get properly with PA and Ultrabeam you need follow with active TX slice - DDutil realize it.
or?0 -
Hi Sergey, I try when I come back at home....0
There is a feature request for a new type of CAT port that tracks the transmit slice. Unfortunately it did not make the cut for 1.6.17
thanks Tim then in a next update we will find again this possibility? omnirig, software much used on many software cwskimmer included, no longer functions properly in functionality split with more active slice for example, would be enough to put the possibility of a COM that reads data on all active slice specifically on what to which is enabled TX at that time0
Are you using the smartsdr.in file for OmniRig?0
Yes always use this file...0
I will need to test the smartsdr.ini file and see if it needs to be modified.0
- 654 The Flea Market
- 384 SmartSDR API
- 51 Aurora
- 967 Maestro
- 938 Genius Products
