New COM philosophy
iz7auh
iz7auh Member ✭✭✭
edited April 2017 in SmartSDR for Windows
I would like to ask a question to the staff, personally own a UltraBeam and an amplifier expert 1.3k necessotabo therefore both are connected to the CAT with the 1.5 version lrecedente they tuned in to all the slice just abilitavo TX on the slice you want by using a single COM now this has become impossible because now there is close correlation COM slice this seems like a step back or there is a way and I have not realized? thank you
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    Frank if i get properly  with PA and Ultrabeam you need follow with active TX slice - DDutil realize it.
    or?
  • iz7auh
    iz7auh Member ✭✭✭
    edited January 2016
    Hi Sergey, I try when I come back at home....
    edited March 2017
    There is a feature request for a new type of CAT port that tracks the transmit slice.  Unfortunately it did not make the cut for 1.6.17
  • iz7auh
    iz7auh Member ✭✭✭
    edited March 2017
    thanks Tim then in a next update we will find again this possibility? omnirig, software much used on many software cwskimmer included, no longer functions properly in functionality split with more active slice for example, would be enough to put the possibility of a COM that reads data on all active slice specifically on what to which is enabled TX at that time
    edited December 2016
    Are you using the smartsdr.in file for OmniRig?
  • iz7auh
    iz7auh Member ✭✭✭
    edited January 2016
    Yes always use this file...
    I will need to test the smartsdr.ini file and see if it needs to be modified.
