Processor Nor DX DX+ info hidden by the status bar...
Mike Agnew
After the upgrade. The words just don't line up where you can read them. Wish I knew had to post a screen shot.
Drag and drop the screenshot into the post window,0
I don't see it - haven't read up to see if it's been moved somewhere else or not but the processor selector is . . . ?0
Yes I see the same. Also maybe while that's fixed you can also widen the area for the mouse cursor over the Volume Slider to match all of the other sliders.
Only the top half of the volume slider is the mouse area.0 -
Duane, you can't see it because your slice is set to CW. It only shows up if you're in SSB.
It's difficult to see, but aren't you in CW mode only?0
Here you can see the NOR/DX & DX+ text is slightly out of alignment.0 -
Well, of course - doh! I'm in CW or RTTY 90% of the time, and the only time I look for it is when I'm in SSB, and there it is. Tonight I didn't even think to switch modes. Thanks for pointing out my error, Rick.0
This looks like some of the GUI controls became misaligned. I will write this up as a defect. Thanks for the screen shot, that is a big help0
Could you also have them look into the the area for the mouse cursor over the Volume Slider to match all of the other sliders.
This existed in 1.5 also.0 -
That defect is already in the bug tracker. I'll see what I can do but I can't make any promises.0
Thanks Tim.
These are all small problems. But I must say I look forward to taking advantage of some of the new powerful features in the new version.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
