Processor Nor DX DX+ info hidden by the status bar...
Mike Agnew
After the upgrade. The words just don't line up where you can read them. Wish I knew had to post a screen shot.
Drag and drop the screenshot into the post window,0
I don't see it - haven't read up to see if it's been moved somewhere else or not but the processor selector is . . . ?0
Yes I see the same. Also maybe while that's fixed you can also widen the area for the mouse cursor over the Volume Slider to match all of the other sliders.
Only the top half of the volume slider is the mouse area.0 -
Duane, you can't see it because your slice is set to CW. It only shows up if you're in SSB.
It's difficult to see, but aren't you in CW mode only?0
Here you can see the NOR/DX & DX+ text is slightly out of alignment.0 -
Well, of course - doh! I'm in CW or RTTY 90% of the time, and the only time I look for it is when I'm in SSB, and there it is. Tonight I didn't even think to switch modes. Thanks for pointing out my error, Rick.0
This looks like some of the GUI controls became misaligned. I will write this up as a defect. Thanks for the screen shot, that is a big help0
Could you also have them look into the the area for the mouse cursor over the Volume Slider to match all of the other sliders.
This existed in 1.5 also.0 -
That defect is already in the bug tracker. I'll see what I can do but I can't make any promises.0
Thanks Tim.
These are all small problems. But I must say I look forward to taking advantage of some of the new powerful features in the new version.0
- 314 Community Topics
- 574 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 242 SmartSDR CAT
- 174 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 119 FLEX-8000 Signature Series
- 855 Maestro
- 50 FlexControl
- 804 Genius Products
- 279 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 695 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 920 Third-Party Software
