Smart Cat Error Msg FlexVSP Services on 1.6 update
Rick Williams
When I updated to 1.6, on reboot there was an error message saying that SmartCat needed FlexVSP Services and to start a support ticket. Haven't had time to fire up the radio yet to see if this is an actual problem or not. Has anyone else encountered this?
Not me.
6700 on Windows 7 64 Bit
I followed the Release Notes to the letter. I uninstalled FreeDV and DStar, turned off all radio related programs, ddutil, etc.. and exited CAT and DAX and Turned off the radio.
I then installed 1.6 without uninstalling 1.5. After the installed it asked me to reboot the computer. By the way, it looked like the installed hanged while installing the DAX drivers. Patience... it just takes a while to install.
After reboot I opened SmartSDR with the new CAT and DAX opened and turn on radio and performed the UPGRADE as you can see here:
https://www.youtube.com/watch?v=kvwk8z1mcCA
No issues!
I had nothing running either and the install process went very smoothly, no delays or hangs. On reboot the Dax window opened and I got the error message. Nothing about VSP occurred during the upgrade.
Rerun the installer. It will attempt to install FlexVSP again if it didn't run properly the first time.0
Yes, simply try another install. It does no harm to install the code over itself. Everything lands in the same places (if files are copied at all), and any steps that failed the first time will be retried. I would do a Restart on the Windows system before reinstalling. Note that on Win 8 and later, Restart is not the same as Shutdown and power up.
I'll give that a try.
Ok, I did a cold reboot and SmartCatSDR popped up and appears to be working. I did a restart on the update, so on my version of Win 7 Pro required a cold boot. Sheesh!0 -
I'm getting the same error. I have tried re-installing 4 times. Same issue every time. FlexVSP seems to be not installing, missing or just not running. Not sure which.
Open a HelpDesk support ticket if you continue to have issues.0
As posted above, I had to do a complete shutdown and restart of the computer, two reboots didn't do it. Have you tried that?
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
