Flex v1.6.17.74 is now posted on the downloads page.
edited May 2020 in SmartSDR for Windows
Jim
 ka7gzr
Welcome!
  • Member ✭✭
    edited October 2018
    Busy server. Too bad this isn't being distributed via torrent.
  • Member
    edited March 2017
    Nothing happening.  Must be overloaded.
  • Member ✭✭
    edited February 2017
    I'm getting an Internal Server Error.  No doubt their Server is pretty busy right now! :^D
  • Member ✭✭
    edited January 2018
    Loaded, running and so far NOTHING appears to be broken.:) Running Windows 7/64
    Lew
    N4CO
  • Member ✭✭
    edited January 2016
    very slow a FRS server
  • Administrator, FlexRadio Employee admin
    edited March 2017
    We are currently having some server resource contention issues.  Please be patient and if you experience an issue downloading, please wait a few minutes and try again.  Repeatedly trying to download over and over again will only exacerbate the problem.  Sorry for the inconvenience.
  • Member ✭✭
    edited May 2020
    what a Mess Tim I downloaded 1.617 and now have a squeal from the DM780 when using digital modes couldn't figure it out and upon uninstall back to 1.5 now have DAX Driver whats the fix for this??
    Ian
  • Member ✭✭
    edited January 2016
  • Member
    edited January 2017
    running v1.617 and DM-780 working fine for me.
  • Member ✭✭✭
    edited November 2016
    I had a small hiccup on install. It told me the radio was not compatible. I clicked OK on the error message and click UPGRADE again and it worked.
    You can see the video of my upgrade here. I thought a bit too late to add the second camera so you don't get to see the beginning of the upgrade with the purple led and the Upgrading message on the LCD.
    https://www.youtube.com/watch?v=kvwk8z1mcCA
  • Member ✭✭
    edited January 2018
    1.6.17 up and running like a champ with all of the usual suite; DDUtil, HRDLog, DM780, HRD Rotator, SDR Bridge, CW Skimmer, FR Stacks & FR Meter.  It installed with nary a hiccup.
  • Member ✭✭✭
    edited December 2016
    I noticed with MON enabled, the XMIT digital tones are heard in the speaker.  That seems new to me.
    HtH.
    k3Tim
    Not new.  Digital mode MON has been a feature for a while.
  • Member ✭✭
    edited January 2016
    Mon is not the issue and I can't get the DAX drivers to uninstall on 1.617.
    getting Dax driver may not be properly installed error message
    Ianimage
    I recommend opening a HelpDesk support ticket.
  • Member ✭✭
    edited August 2016
    I will try in February after bugs are found (no one is perfect)
  • Member ✭✭
    edited March 2017
    Is there a corresponding firmware update with this SW update this time?
    N4GA
  • Member ✭✭
    edited January 2018
    There is effectively a firmware update with every release of SSDR.  That's why initially it tells you the radio needs to be upgraded.
  • Member ✭✭
    edited January 2018
  • Member ✭✭
    edited January 2016
    That's what I thought. The reason I asked is the radio did not do the usual purple light firmware update this time..
    Did yours?
    Usually SSDR stops you and says "Update Firmware"
    There is a firmware release with every version of SmartSDR.  If you are running the 1.6.17 GUI with your radio and it isn't wanting to upgrade, then you have the proper firmware loaded.
  • Member ✭✭
    edited January 2016
    Thanks Tim. Radio is working fine. Sitting on the lazy boy listening to 40m right now via LAN.
    You guys are awesome!
    Rob
    Cool.  I need to step away from the PC and go watch the game.
