Flex v1.6.17.74 is now posted on the downloads page.
ka7gzr
Jim
ka7gzr
Busy server. Too bad this isn't being distributed via torrent.0
Nothing happening. Must be overloaded.
I'm getting an Internal Server Error. No doubt their Server is pretty busy right now! :^D
Loaded, running and so far NOTHING appears to be broken.:) Running Windows 7/64
Lew
N4CO0 -
very slow a FRS server0
We are currently having some server resource contention issues. Please be patient and if you experience an issue downloading, please wait a few minutes and try again. Repeatedly trying to download over and over again will only exacerbate the problem. Sorry for the inconvenience.0
what a Mess Tim I downloaded 1.617 and now have a squeal from the DM780 when using digital modes couldn't figure it out and upon uninstall back to 1.5 now have DAX Driver whats the fix for this??
Ian
Try this: https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSD...
I have it installed with zero issues so far0 -
running v1.617 and DM-780 working fine for me.
I had a small hiccup on install. It told me the radio was not compatible. I clicked OK on the error message and click UPGRADE again and it worked.
You can see the video of my upgrade here. I thought a bit too late to add the second camera so you don't get to see the beginning of the upgrade with the purple led and the Upgrading message on the LCD.
https://www.youtube.com/watch?v=kvwk8z1mcCA
1.6.17 up and running like a champ with all of the usual suite; DDUtil, HRDLog, DM780, HRD Rotator, SDR Bridge, CW Skimmer, FR Stacks & FR Meter. It installed with nary a hiccup.0
I noticed with MON enabled, the XMIT digital tones are heard in the speaker. That seems new to me.
HtH.
k3Tim0 -
Not new. Digital mode MON has been a feature for a while.1
Mon is not the issue and I can't get the DAX drivers to uninstall on 1.617.
getting Dax driver may not be properly installed error message
Ian
I recommend opening a HelpDesk support ticket.0
I will try in February after bugs are found (no one is perfect)1
Is there a corresponding firmware update with this SW update this time?
Thanks,
N4GA0 -
There is effectively a firmware update with every release of SSDR. That's why initially it tells you the radio needs to be upgraded.0
There is effectively a firmware update with every release of SSDR. That's why initially it tells you the radio needs to be upgraded.1
That's what I thought. The reason I asked is the radio did not do the usual purple light firmware update this time..
Did yours?
Usually SSDR stops you and says "Update Firmware"
Thanks0 -
There is a firmware release with every version of SmartSDR. If you are running the 1.6.17 GUI with your radio and it isn't wanting to upgrade, then you have the proper firmware loaded.0
Thanks Tim. Radio is working fine. Sitting on the lazy boy listening to 40m right now via LAN.
You guys are awesome!
Rob0 -
Cool. I need to step away from the PC and go watch the game.1
