Mic and audio interconnection cookbook
Duane N9DG
Frequently there are questions about making up mic or audio connects to, from, and between radio and audio gear. I have found this technote by the Rane Corporation to be excellent, and with many practical examples for how to interconnect two pieces of analog audio equipment. I use it as my "cookbook" guide for anything audio that I deal with.
http://www.rane.com/note110.html
That technote covers transitions between balanced and unbalanced worlds, various realities of the "grounding" internal to differing pieces of equipment (AKA the "pin 1 problem"). And this technote is entirely consistent with K9YC's writings on the topic...
The only thing this technote does not have information about is PTT connections. That is because it was written for those who work in the broadcast and pro audio worlds.
2
Thank you ! A nice resource.0
Good stuff, thanks. I also have this saved away, which I found on this site - somewhere, sometime:
Many audio complaints are due to miss wired microphones. Pin 7 , is not for shields or connecting to pin 5 (chassis ground). Pin 7 is for mic minus only , Pin 8 is audio. And some mic plugs can be rotated 180 degrees, so be careful . Some commercial cables are mis-wired, so be sure that pin 7 is not shorted to pin 5.
-Dudley
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
