Mic and audio interconnection cookbook
http://www.rane.com/note110.html
That technote covers transitions between balanced and unbalanced worlds, various realities of the "grounding" internal to differing pieces of equipment (AKA the "pin 1 problem"). And this technote is entirely consistent with K9YC's writings on the topic...
The only thing this technote does not have information about is PTT connections. That is because it was written for those who work in the broadcast and pro audio worlds.
Thank you ! A nice resource.0
Good stuff, thanks. I also have this saved away, which I found on this site - somewhere, sometime:
Many audio complaints are due to miss wired microphones. Pin 7 , is not for shields or connecting to pin 5 (chassis ground). Pin 7 is for mic minus only , Pin 8 is audio. And some mic plugs can be rotated 180 degrees, so be careful . Some commercial cables are mis-wired, so be sure that pin 7 is not shorted to pin 5.
-Dudley
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
