Flex-6300 disconnects at double click in second panadapter while having two slices active in the fir
PA2TA
PA2TA Member ✭✭
edited March 2017 in SmartSDR for Windows
Recently i noticed a small bug in my Flex-6300: with two active Panadapters in SSDR and two Slices opened up in the first one (and thus no Slice in the second Panadapter), the Flex-6300 disconnects when double clicking anywhere on the second Panadapter. SSDR shows a message that the radio is disconnected and returns to the Select Radio Window, however the Flex doesn't show up anymore. The Flex can only be power-cycled by holding the power button until it shuts down. After that the Flex can be switched on as usual and it works fine as long as the above is not repeated. The problem is reproducable, no matter what band or mode is selected on the Panadapters/Slices.
Anyone experienced a similar problem? (I've seen the problem when double clicking on the Band Switch, but that one crashed SSDR, not the radio).
SSDR v1.5.1.152
Flex-6300 v1.5.1.70
Windows 7
Tjakko PA2TA
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited March 2017
    I believe is a known issue to be fixed early next week with ver. 1.6 of SmartSDR
    More info HERE
  • Tim - W4TME
    edited March 2017
    Salvador is correct.  This issue has been addressed in the soon to be released SmartSDR v1.6
  • PA2TA
    PA2TA Member ✭✭
    edited November 2016
    Thanks for the reply, that sure looks like the same problem.
    Tjakko PA2TA
