Birdview toggle switch
Takeshi Yamada
Takeshi Yamada Member ✭✭
edited September 2018 in New Ideas
Idea) Toggle button to widen and narrow panadaptor window showing range of frequency.
Two years has passed since I started using Flex6500 and now the panadaptor is an indispensable tool like fishfinder for fisherman.
When I dig into the very narrow band width to find a rate one, I sometimes want to see what is happening on this band other segment from macroscopic view (birdview), like 14000 - 14350Khz, with a push of button and coming back to the current position with another push - back and forth in an action.
Left corner of the panadaptor window is left open for such toggle switch?
73 de JI1BNU
Ken Yamada
2 votes
In Review · Last Updated
  • Brent Parker
    Brent Parker Member ✭✭
    edited December 2016
    I'm  basically doing that with macro's in DDutil.  I'm running a MFJ Mag Loop and it really helps, when changing bands to get out to that wide view and then turn the loop. You can see where it's tuning to.
    I have three settings:
    Narrow:  DD6PBW0:.075;
    Normal:  DD6PBW0:.275;
    Wide:     DD6PBW0:8.2000;
    These set the width, to 75, 275 and really wide at 8200!  The last one is great to watch the mag loop cap turn from 20 meters to 40 meters.
    However, having it built into the panadaptor, would be great too!
    Brent W8XG
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    I do the same with a Genovation 24 Keypad and DDUTIL Macros
    Push a Key - Zoom In   Push a Key - Center - Push a Key Zoom Out
    Much faster than moving a mouse to a spot on a Screen
  • Brent Parker
    Howard, do you have the macro handy, for center?  Thanks
  • KY6LA_Howard
    edited January 2017
    DD6PCF0;
  • Brent Parker
    Installed. Perfect. Thanks!
  • Wayne VK4ACN
    Wayne VK4ACN Member
    I'll try these when I get home. Thanks all 73 Wayne
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    Hi Ken,
    Here is an idea I posted a while back to show both the macro and micro slice views at the same time.   It's a different approach but may be of interest.
    https://community.flexradio.com/flexradio/topics/****_slices_idea_to_synch_up_2_slices?topic-reply-...
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
    6700 - HW......... V 1.5.1.70
    SSDR / DAX...... V 1.5.1.152
    CAT................... V 1.5.1.0
    Win10
  • Takeshi Yamada
    edited January 2016
    It works!
    Thank you!
