I cannot access 2 meter repeaters
edited December 2019 in FLEX-6000 Signature Series
I need a little help. I have my 6700 setup with a 147.320 RX - 147.920 TX split for a local repeater. I am in FM mode, and do have the DEMI amp on which puts out up to 50 watts on 2 meter FM. I see the power out, but cannot "break" the repeater. I hear the traffic on 147.320 OK. Where am I going wrong?
Welcome!
  • Member
    edited February 2019
      Does it have a pl tone?
  • Member ✭✭
    Agree with Joe ..... transmit Tone needed?
  • Member ✭✭✭
    I've been known to transmit on the wrong slice from time to time. Or antenna.
  • Member ✭✭
    edited November 2016
    OK that's logical, how do I add the pl tone?
  • Member ✭✭
    how do I add the pl tone to my TX slice??
  • Member
    edited January 2016
    I am not sure you can. I don't have a 2m transverter.  You would need a tone board for that if its not built into the transverter.
  • Member ✭✭
    I see the CTCTX and have turned it on, however I don't know what to select below that window for tone type for 2 meter repeaters
  • Member ✭✭✭
    edited January 2017
    RTFM
    Change the value in the drop down list XZ to your PL
  • Member ✭✭
    edited December 2016
    Hi Dave,
    I don't have a transverter but here is some info you might use.
    You should listen on 146.920 and transmit on 146.320 with a PL tone of 103.5.
    The repeater is one of the WB5UGT/SALTGRASS group.
    I'm sorry I can't help with the setup of your transverter. This info is from the 2014 ARRL Repeater Directory.
    73 - Roy - W5TKZ
  • Member ✭✭
    Thanks Howard, I have done that. My repeater tone requires 114.8. I have set that as 16 2A 114.8 but still cannot break the repeater.
  • Member ✭✭✭
    Did you turn Off to ON above it?
  • Member ✭✭
    Where is the off-on switch?
  • Member ✭✭✭
    edited January 2016
    It's the furor down above the where you set PL frequencies.
  • Member ✭✭✭
    edited January 2016
    Also make sure your transmit low cut is set to zero for FM as you need to send low frequency tones
  • Member ✭✭
    Howard, tnx for your help.
    Yes, I have it turned on, and low cut set to zero. Still no joy. Can't access the repeater. Split is correct, TXing on the +600 mHz as required by this particular repeater. I can access the repeater easily with my 1 watt handheld. Go figure.
  • Member ✭✭✭
    edited January 2016
    Reverse the handheld and see if you can hear whether or not you are transmitting the sub-audible?
  • Member ✭✭
    Howard, GOT IT. The repeater tone listing was given incorrect on the internet. Fixed that to 151.4 and all works now. Again thanks for your help.
