Cat commands questions
IW7DMH, Enzo
Hello,
while I am writing a program that uses some CAT commands I found the following errors:
- ZZGT return always ?; when AGC mode is med;
- ZZRX return always ZZRX1 also when the MOX button is not pressed;
- ZZTX return always 1 also when the MOX radio is in receive mode;
- ZZSM return always ?;
- NB commands: I can set the NB level using the ZZNL command but I can't find a command to enable/disable it;
- NR commands: I can enable/disable it using the ZZNR command but I can't find a command to set the level.
I am referring to the official "SmartSDR CAT User Guide" v. 1.16 published on 09/10/2015 and it seems, now, that the download of the same document is not working. You can download only the German version.
I am wondering if there are undocumented commands that needs to be listed.
Thank you very much and I wish you Merry Christmas and Happy New year
73' Enzo
iw7dmh
73' Enzo
iw7dmh
Recommend referring to these prior posts.
https://community.flexradio.com/flexradio/topics/cat-1-4-3-command-issueshttps://community.flexradio.com/flexradio/topics/matlab-cat-control
Most of these issues are known. Hopefully, they will be resolved in upcoming editions.
I continue work on the MATLAB classdef with all the Ethernet commands. Should have that done in mid January.
73/gus
Hello Gus,
thank for your answer, I didn't aware of the previous issue post.
I am working on an auto-switch box that use my Arduino libraries and some friends asked me to add phisical serial ports to it. It should be a great value for a computer-indipendent device and I would like it could work properly.
I like very much your Matlab work and I am wondering if you have ever thought to use Matlab to print a 3 dimensional panadapter.
Thank you again and Best Whishes
Enzo
iw7dmh
Am currently working on the Java UDP interface to efficiently capture the panadapter and other VITA-49 information. I have been looking at a waterfall view, but the 3D view would be easy to implement. That is an interesting idea. I use 3D freq-time-amplitude plots all the time.
Best wishes to you.1 -
The CAT "engine" and the user interface has been completely re-written for the upcoming SmartSDR v1.6. A lot of these issues should addressed with the re-write.1
any update on the V1.6 ETA ?
I notice cat is logging messages in:
.../FlexRadio Systems/SmartSDR/Cat/Logs/
is there a way to turn these off?
Thanks for the Happy Holidays wishes in multiple languages. Allow me to fill in the one missed one language though (if I may be so bold):
.... .- .--. .--. -.-- .... --- .-.. .. -.. .- -.-- ...0
- 632 The Flea Market
- 126 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
