Low audio on Slice B
You will find, unfortunately, that if you are using the equalizer on slice A and have it adjusted for gain, that slice B will not be equalized and, therefore, sound lower in volume.
Jim, K6QE
Wow! Quite right, I had no idea that the EQ applied only to Slice A, and there is no indication on the EQ. When you switch between Slice A and Slice B the EQ panel remains unchanged making it appear that it is still active! This is either a design problem or a bug.
Is there a way to make the EQ apply to both slices? I need my EQ settings to compensate for diminished hearing.
This might be a design decision the idea being equalization on one person might not apply to another. However, there remains the gain problem which I dislike because when I listen to both sginals mixed one sounds louder than the other. A work around would be using a mixer on slice B and bringing up the gain to match. The problems was also on the Power SDR software.
Jim, K6QE
It may be a bug ... I submitted a Ticket because nothing in the documentation says it should work that way. Tim was surprised and said he could not duplicate it - he is looking into it.0
I concur, its a bug. It doesn't matter if it is by design or inadvertent. It's this type of thing that should be fixed in 1.x, just to connect the dots between two threads. Equalizer is an object belonging to Radio. It is not a Slice object so once set it should be set everywhere.1
In the object oriented world, just as in the real world, there are 'things' of type 'whatever'. Some of those 'things' contain other 'things'. A car as an engine, passenger compartment, trunk, tires.
An engine has cylinders, valves, injectors (or for us older folks, calibrator. The things are called objects and the whatevers are called classes. One can organize these into a sort of organization chart called an ERD or entity relationship diagram. In contrast to containment there are derived objects where a instance, while being of one type directly, is indirectly another type. A class ring is a ring just as a wedding ring is a ring but a class ring is not a wedding, right? A little background for those interested.
In the SSDR world, the root 'thing' is the radio and it directly has several other things, like panadapters and slices and an equalizer. Where there is only the one equalizer, owned by the radio, which in turn owns the pans as well as the slices, it would stand to reason the various slices would share the same settings as they share the same equalizer object (singular).1 -
Can someone tell me what he just said?0
Which part, or were you just being snarky? Some people expressed interest in how the software works, so the fist part was a lead-in to the second paragraph as well as something of a tutorial to those expressing interest. The second paragraph was explaining why, based on the design, I concluded it was a bug, as the slice doesn't own the equalizer, the radio does.0
I am just one of those low class, **** hams that like people to express instead of impress.1
Um, that WAS expressing. But now we know where you are coming from.0
Jim you are well aware if a ham can use 500 words to express, they use 1000 words to impress. Laconic is not in the ham operators vocabulary.1
Awwww...boys, that was the short version.
All kidding aside. I am not trying to be snarkly here. There are many people who would like the opportunity to learn more about what's behind the curtain as far as how flexlib works, which gives a view on the ERD of SSDR. From that knowledge one can deduce how other things hold together.
I did not say any of that to 'impress' anyone, not even myself. I was trying to be helpful to the author of this thread and others who might want to learn something about the inner workings of SSDR as it relates to the relationship between the radio object, the pan object and the, in this case, equalizer object.0 -
There is an acknowledged bug in the latest software that when opening a second slice on a pan the RX EQ doesn't engage for that slice. If you switch modes and return then it does engage. This was reported a while back. This may be your problem.3
I just brought up slice B and it did not function with the equalizer. I changed modes on slice B to CW and back to LSB, and, sure enough, both slices now worked with the equalizer. Thank you for the info. I am sure a lot of others with thank you also. This bug must have been lost as I don't recall ever reading about it.
Jim, K6QE
Very good Ken! Thanks for the workaround while Tim works on the bug fix.0
The RX EQ interaction (or lack there of) on a cloned slice is a defect that will be fixed in the next version of SmartSDR.0
Hi Tim, HNY. Apologies if this sounds like a request for you to state the obvious. When you say next version, do you mean 2.0.x or a 1.6.x?1
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
