CAT macro to turn RX Antenna on?
Barry N1EU
Is it possible to program a SmartSDR CAT macro to set the receiver to RX A (rcv antenna)? I'm hoping to be able to quickly switch between TX antenna and Beverage so would like to use a CAT MACRO programmed into an N1MM Logger+ function key if possible.
I don't see it listed in the CAT documentation and I don't see it listed as an option on the FlexControl.
(sorry for all the newbie questions - trying to get up and running quickly and jump into the 160M cw contest)
Thanks & 73,
Barry N1EU
Thanks & 73,
Barry N1EU
Barry,
If you use DDUtil, then DD6RXA should do the job..
AL, K0VM
Thanks Al! I will try to get that working. I just wish I could have separate DDUtil config profiles for my PowerSDR and my SmartSDR.
73, Barry N1EU0 -
Barry,
The macro files are stored seperately for 6000 vs. legacy.. check the DDUtil files tab in setup..
AL, K0Vm1 -
Barry... Did you take the plunge with the 6000 series? Looking forward to hearing you in the air again.0
Yes Sal, playing with a 6500 in the shack now. Not sure if I'd call it a "plunge" though - more like an experiment ;-)
Barry N1EU0 -
Well, email me today if you want to do some in the air testing0
For smart SDR and PSDR I use separate versions of DDUTIL I use V 2 for PSDR and V3 for SSDR. I can then run both programs at the same time one for the Anan and one for the Flex and neither knows the other is active. The macro screen in DDUTIL allows buttons to be made push on, push off or push once choice A push again choice B For my 6500
22 ANT1-XVTR DDTG11:061:062; resides in slot 22
and
61 Ant 1 DD6RXA0:0;DDSI:1:ANT1;
62 XVTR DD6RXA0:4;DDSI:1:RX1;
reside in their respective slots in the macro database. When I press slot 22 once Ant1 is the RX ant when I press 22 again XVTR is the RX antenna (in slice A) DDSI publishes an annunciator in the first of the 3 boxes at the bottom of DDUTIL. Either ANT1 or RX1 is published so at a glance I can tell which antenna is active on RX. You could also set up another button to switch between RX-A and XVTR if you happen to have a beverage and a loop RX ant for example and make any of those choices publish in the box. (I use the XVTR choice because I also have a 6300 and it's convenient if I switch antennas between rigs)
73 W9OY1
- 383 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 934 Genius Products
- 342 Tuner Genius XL
- 303 Shack Infrastructure
- 142 Amateur Radio Interests
