Odd behavior when offset for wsjt-x is greater than 3k...anyone else see this?
mdavid01
mdavid01 Member
edited January 2018 in FLEX-6000 Signature Series
I've been spending a lot of time using WSJT-X for JT-65 and JT-9. Enjoying digital modes more than I anticipated.
I've noticed that every so often when the offset is greater than 3k the flex will show the red TX transmit, however in the waterfall it shows no signal and nothing noted in panadapter either.
Here is what SmartSDR looks like during this event
Anyone else notice this behavior with WSJT-X and SmartSDR?
  • Cedric HB9HFN
    Cedric HB9HFN Member
    edited December 2015
    Set your TX High Cut > 2900 (e.g. 4000)!
  • W7NGA
    W7NGA Member ✭✭✭
    edited January 2018
    What Cedric says and don't forget to setup a JT65 profile otherwise it will be a recurring problem. I tend to forget to enable DAX as source on transmit when bouncing from JT65 and SSB modes.
  • mdavid01
    mdavid01 Member
    edited November 2015
    Dang that was fast for the exact right answer!  Thanks!
  • Phil M0VSE
    Phil M0VSE Member ✭✭
    edited September 2016
    Another fix for this is to use the fake split mode of WSJT-X, this will automatically increase or reduce the frequency enough to keep the transmit signal at around 1.5k and return to the correct frequency on receive.
