Lighting router wifi
I think you mean by "wifi," right? Yes -- it's very do-able. The rig itself doesn't need internet at all, so you can eliminate that path completely if you choose. One CAT cable to the PC. The PC can then run wifi for your internet applications. Some folks have used ethernet to fiber converters to take even that copper path out of the equation.
Of course, your biggest threat from lightning comes from the antenna connection, and then the power line. Nothing beats a good disconnection for protection. Polyphasers, etc., can help when properly installed, too.
I connect to my 6300 via Wi-Fi router without any issues. The only caveat is you need a very good signal.0
Thank you George,
I will heed that advice too, when I get the station set up..
(Still in limbo with remodel)0 -
Actually Republic of the Congo and Venezuela have more annual lightning hits than Tampa Florida, according to NASA data0
On lightning, see W8JI's material:
http://www.w8ji.com/lightning.htm
Bottom line: most important factor is to use a grounded single-point entry panel that bonds all wiring including ethernet, antennas, and power at the entry. This prevents damage because all potentials rise and fall together, preventing damaging internal voltage differentials and current flow.
For wireless LAN you can use "wireless bridge" modes. Here's a picture:
http://www.dd-wrt.com/wiki/index.php/Image:Client_Bridge.jpg
Get a router that can run DD-WRT firmware (http://www.dd-wrt.com), load that, and configure it as a "client-bridge" or "repeater-bridge". I've done it many times.
- Les, W9XC
Been using wi-fi here on the PC for the Flex for a few years. No problems at all with either a 2.4 or 5 gHz connection. Internet speed is plenty fast through a Rosewill (Newegg house brand) USB dongle.0
A better alternative to WiFi would be fiber optic cable, if your goal is to electrically isolate the radio (and your computer) from your network cable.
Peter
K1PGV
Everyone would be wise to protect their Internet connected high dollar equipment. Three years ago I lost ALL of my solid state rigs, to the tune of nearly $14,000! Fortunately, my homeowner's insurance covered all of it but a $500 deductible (check to see if your insurance covers your gear without the need for a special rider - mine did, fortunately). I had been lucky for the previous 34 years as a Ham.
I can definitely tell everyone that you need to protect your Ethernet devices. My station took a surge through the CAT5 cabling I have run throughout my QTH. It was not a direct strike, but rather a surge from nearby lightning. I had just connected all my solid state radios 2 weeks prior via RS-232 or USB/SignaLink devices. The surge traveled through my Ethernet wiring, through my shack PC, then out to the RS-232 and USB devices after traveling through the PC's motherboard.
Since I had to buy all new equipment, I now have my Flex 6300 as well as a Kenwood TS-990 connected to my 100 Mb switch through APC brand model PNET1GB surge protectors. I have USB and/or RS-232 connections to other radios through USB surge protectors, and utilize a USB hub to disconnect ALL USB devices when not in use. My station is properly grounded now (much better than it was before), including the tower being tied into the rest of the ground system. Of course I also have surge protectors on ALL antennas/incoming coaxes.
Wi-Fi, fiber-optic, or Ethernet surge protectors are all advisable to isolate Ethernet connected equipment. The only items I don't protect are low-dollar items like network switches, etc.
Please heed Jim's original post and think about protecting your valuable equipment beyond just the antenna system!
Greg - N8GD
Do a search on www.ctcu.com
Look at the part numbers FSW-2104 & FMC10 You will also need the correct fiber interconnect cables. Then from the FMC converter you can run cat 5 to your flex.
Email me direct with any questions..Good on QRZ0 -
Thank you George,
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
