Writelog will not key CW on flex 6500
W5NE
Writelog recognizes Flex 6500 and frequency is tracked but I cannot get writelog to send CW to the flex 6500. I must be missing something in the port setup in writelog.
The Writelog port setup has a radio button for CW but it cannot be selected without a com port, but with Flexdriver1130b the 6500's serial number is used instead of a comm port number.
Please help
Set up: Writelog V11.30 with WI Flexdriver1130b.exe Flex 6500 with Smart SDR v1.5
Please help
I do not think the WriteLog flex driver is supposed to handle CW. I have read through the program notes and no mention of CW is in it. (If it is, will someone speak up)
I use a WinKeyer2 USB box assigned to a com port and configure WriteLog to do the same. Output of the box goes into the cw port of the Flex. Be sure to disable the Iambic keyer in the Flex settings.
It all works good - can even change the CW speed with the knob on the WInkeyer and have the speed displayed in the WriteLog status window.
If you find an alternative path - I am sure many ears will perk up - including mine - always trying to get rid of as many boxes as possible..
Cheers
Thanks for the reply Walt. It seems unlikely that Writelog would stop supporting cw. I remain optimistic that there is a solution. In the meantime I will get stress management and try N1MM logger.
730 -
I think it is more that SmartCat does not assign an rs-232 pin for CW input. I have looked at N1MM+ and I think it too requires a keyer to send CW to the Flex, but I could be wrong again. There are so many updates to N1MM that what might have been a few weeks or days ago is no longer true.
Maybe someone will chime in or I am sure there is an on-line help guide for N1MM+ for Flex setups.
GL - its all adventure !
This is correct. We do not support CW keying via "bit banging" a com port.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
