install psdr for F1500 using windows 10
DonS
Member ✭✭✭
I finally decided to setup the F1500. I downloaded the latest version of PSDR ver 2.7.2. During the install of PSDR the following - see attached. I continued with the installation, however, one thing I noticed was that I did not see a com port associated with the USB to the F1500.
PSDR does come up, however, there is no data on the panadapter. This is a relatively new computer which never had PSDR installed previously. Any thoughts?
Don
Don
When you installed PowerSDR, you selected the option to do a restore point. Your PC is not running Windows scripting which is required to execute the restore point.
Uninstall PowerSDR, using the complete uninstall option at the end of the un-installation process, reboot the PC and re-run the PowerSDR v2.7.2 installer, but do NOT select the option to create a restore point.
And, there is no comport associated with the USB as it is not used in that manner. From a Windows perspective, it is used as an audio device. This KB article may be informative in determining if the 1500 drivers are installed properly. http://kc.flexradio.com/KnowledgebaseArticle50479.aspx
Thanks Tim. That took care of the problem and it looks good in Device Manager. Now I have to setup VAC. If I recall, I thought I could use the serial ports setup by FlexRadio VSP as long as I don't have the 6700 on. Is that correct?
Don
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
