Anyone using an ICOM PW-1 with their Flex 6000?
KF4HR
I found a similar question posted 2 years ago but I'm wondering if anything new has come about since then concerning interfacing the the ALC voltage range difference between the 6700's ALC range (-4 to 0 vdc), and the ICOM PW-1's ALC range (-10 to 0 vdc). Do the newer software versions allow the 6700's ALC range be adjusted with now? If not, what are my option(s)?
KF4HR
KF4HR
Two options. Make a voltage divider with a. Couple of resistors Better Use DDUTIL and just use autodrive. To set the max drive levels. I used DDUTIL for years with no problems. Plus you don't get the distortion caused by ALC0
Thanks Howard. I went ahead and downloaded DDTIL V3 and have been looking it over. I assume when the autodrive parameters are adjusted correctly there's no need for an ALC cable? Do I have that correct?
Correct0
I never could get the ALC to work properly with the PW1and I was very happy with how well DDUtil worked with the PW1. Definitely the way to go. I also drove my SteppIR controller using the second remote port on the PW1.0
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
