Make “quick select” modes persistent per band
In the latest software manual, section 8.4, page 30, it explains how to set the three quick select mode buttons that always show next to the mode drop-down. I have mine set to USB, CW, DIGU. But when I go to 40 meters and below, I want LSB instead of USB. So I end up using the mode dropdown a lot more than I would like.
So, logic to change the quick select USB button to LSB when band appropriate could be added. Or just make the three quick select modes persistent per band.
If persistent per band, you could also do things like not having either USB or LSB on 30 meters, or adding FM only on 10 meters, maybe AM only on 80, etc. I’m sure there are more useful band combinations based on our personal usage patterns.
73, Bob, N7ZO
P.S. A simpler solution might be to just add another row of quick select buttons, but that would take up more panel space.
Thank you Bob. I use the new mode RTTY all the time and had to dig down in the menu to get it. Now I have one of the Quick mode set for RTTY.
Joe K0BX
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
