Acom2000A or SPE 2K A
Ross Biggar
This is not really a question. I wish to thank all of you who replied to my question about the Acom 2000A or the SPE 2KA . Interestingly 62% of the answers were in favour of the SPE amplifier, where there was some doubt about which type I gave the reply a 50/50.
I can see advantages in either amplifier. The Acom has a remote head, which would suit nicely, but the SPE appears to have more flexibilty. On pricing it seems they are virtually identical.
I will probably go for the SPE unit, now to wait for their quote.
Thanks all I really appreciate your replies.
Ross
ZL1WN
Ross
ZL1WN
Ross Maybe you should consider repair issues with both as well. There are some issues with both. Personally I dont care about remote head as I use DDutil. It should work with both Amps however Acom 2000 is already coded while SPE2ka isn't. Ian0
Too bad your are not. In the USA and at Dayton Hamvention this year They were having show special pricing of $6,495US for the 2K HOWEVER. Flex announced tonite that they will be brining out a Solid State Full Legal Limit Amp with 4O3A as Designer which will be network via Ethernet to the 6000 series. No real details yet but enough of a hint that one of my buddies decided to put off his 2K purchase to see what Flex will bring out.0
That is very exciting. I hope the price will be competitive with the 2K and the A2000.
They are both great amps. A new product like this may a long way off, though.
Ned, K1NJ
Design is not that difficult. The issue will be the delay in getting regulatory approval given the usual bureaucratic nonsense required for Amps. No idea as to pricing or actual delivery dates or features except that it will be a networked device.0
Howard Is there any hint at pricing and are they taking orders? Ian0
Too early to tell0
I will put more order in, at least I can use the Amplifier down here in NZ without waiting for the FCC,s approval.0
I had a Acom 2000A and if the line voltage got 1/2 v out of spec the amp would shut down. I live out in the country in FL east of Orlando and given the air conditioning load here it's not unusual to see a couple volts line variation. I wound up selling the Acom, nice amp but too much hassle
73 W9OY1 -
I have owned the Acom 1000 and the Acom 2000A
Both well engineered amps, but producing large amounts of unwanted heat into the shack even on idle. The valves will eventually become a sourcing issue.
The 2000A does not cover 6m, you need the 1000 to do that. Both amps lack flexibility in terms of input and outputs.
I now have the 'bombproof' Expert 2k.
You get 2 PL259 inputs for 2 separate transmitters, which can be automatically switched to six PL259 antenna outputs in any combination from 160m thru to 6m, with peak output of 2,400 watts PEP.
That's how it is...
G4BIM
Any further rumors about the FlexAmp? I'm looking for a good 160-6m amp with QSK. Acom looks good, and even the small Elecraft, too. I don't care about "legal limit" - 500 or so watts is plenty for me. Opinions?0
Like everything else with Flex. It will happen when it happens. Best guess Dayton 2016 if they can get thru regulatory nonsens in time. Definitely go solid state. Instant on is great as you don't miss those rare ones waiting for filaments to heat up. I have lot of friends who lost Q's waiting 4 minutes for Alphas to start.0
No price hints and we are not taking any pre-orders.0
- 275 Community Topics
- 517 The Flea Market
- 7.4K Software
- 6K SmartSDR for Windows
- 143 SmartSDR for Maestro and M models
- 345 SmartSDR for Mac
- 247 SmartSDR for iOS
- 228 SmartSDR CAT
- 167 DAX
- 350 SmartSDR API
- 8.7K Radios and Accessories
- 831 Maestro
- 43 FlexControl
- 842 FLEX Series (Legacy) Radios
- 785 Genius Products
- 413 Power Genius XL Amplifier
- 273 Tuner Genius XL
- 99 Antenna Genius
- 236 Shack Infrastructure
- 161 Networking
- 397 Remote Operation (SmartLink)
- 121 Contesting
- 613 Peripherals & Station Integration
- 122 Amateur Radio Interests
- 850 Third-Party Software
