flex control
Bill Carnett
Not sure what's wrong. When I upgraded to the 1.5.1 a couple of weeks ago, the Flexcontrol started working again. Today turned on rig, said I had to downgrade software? But that was the only way it would start up. Did that and Flexcontrol not working. Just upgraded again to 1.5.1, rig is fine but Flexcontrol doesn't work. Not even recognized...just like with the prior software version. Suggestions?
Bill
Did you by any chance click on an old v1.5.0 shortcut to start SmartSDR?
That would force the downgrade.
It sounds like the FlexControl got fouled up by doing a forced downgrade install, then the reinstall of v1.5.1.
This link may help.
https://helpdesk.flexradio.com/hc/en-us/articles/205004159-How-to-Manually-Reinstall-the-SmartSDR-FlexControl-Driver-
You might need to use the correct full uninstall procedure, to get it correctly installed at this point. In which case this link might help.
https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSDR-for-Windows-from-your-PC
73, Jay - NO5J0 -
Bill,
If you don't uninstall previous versions it is all too easy to confuse the life out of yourself! New versions create new icons, but if you also have start-menu or task bar icons too, then these do not get updated. Therefore it is all too easy to click the old versions' icon and end up being asked to "downgrade" (to get the old version working). I've done that mistake a couple of times now, and thus always make sure old versions are completely removed first.
Not sure why the flexcontrol won't work after re-upgrading, but I'd suggest a full removal of all versions, then a reboot, then a re-install 1.5.1 should sort it.
Cheers, Steve G1XOW
Bill, Just a thought. I had to replace the USB connector on mine. I could wiggle the connector at the computer and it would work for a while but would quit later on. I used a cable and connector from an old mouse. No problem since.
Roy - W5TKZ0 -
Bill,
I suspect that you have a USB COM device conflict as a result of the install/reinstall process.
Open the Device Manager and find the COM & LPT devices entry. You should find an entry in that list for the FlexControl. Click on the item with the right mouse button and select properties. On one of the tabs you will find an Advanced button - click on this and you will be able to reassign the COM port number for the FlexControl.
There is a detailed guide to how to do this here:
https://helpdesk.flexradio.com/hc/en-us/articles/205677445-How-to-Manually-Reinstall-a-PowerSDR-FlexControl
Stu K6TU0 -
Bill C - If the problem persists, I recommend that you open a HelpDesk support ticket (http://helpdesk.flexradio.com) so we can investigate further.
- 690 The Flea Market
- 197 SmartSDR+
- 461 SmartSDR for Mac
- 113 Aurora
- 976 Genius Products
- 483 Power Genius XL Amplifier
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
